offroadTB.com • View topic - Homemade Oil Pan Skid
by dvanbramer88 » Tue Jun 19, 2012 9:04 pm
A while back i had 2 big sheets of 3/16th steel in my scrap pile. Me and Josh have been talking about making a skid plate. I put 2 and 2 together and the wheels started turning. I made a cardboard template. My dad has a lot of steel working equipment at work including MIG and TIG welders. I gave him the template and a sheet to take to work. He came back with this first rough draft.
(I know the drain plug guard is on the wrong side, he messed up following directions) I ground it off and re-welded it on the correct side this morning.
Test fit before a little bit of trimming
(Welded my initials into it, on the rear "fold")
Orange base coats.
Flat black top coats. (Scratches should appear as orange, deeper gashes should be white.)
I didn't take a picture of it, But i reinforced the space between the oil pan and front "fold" by welding angle iron to the top side forming a triangle.
Took about 4 hours to move and re-weld the box, trim, and grind the edges, bend it, and paint it up.
by bartonmd » Tue Jun 19, 2012 10:12 pm
Good job!
A couple things I'll just throw out there...
1. Looks like you're using the corners of the box as the "drains", but I highly suggest against that. The corners are what gives it strength. I would weld the corners up completely, and have a hole in the bottom for a drain.
2. The weld with your initials in it has a lot of porosity in it. What flow rate was the gas set at? Looks like the gas was set low, or the shield cup to tip was clogged up with spatter.
by dvanbramer88 » Tue Jun 19, 2012 10:28 pm
by bartonmd » Wed Jun 20, 2012 9:13 am
Take a piece of angle iron and cut it the length of the height of the box, then put it on the outside and weld inside and out, and all around it.
70A (110V) stick welder makes sense... Not nearly enough heat for any kind of good sized rods. Don't want to use rods thicker than 1/8" at the very most, and you're moving too fast. You have to go really slow with anything 110V. If you're getting porosity on a stick weld with material that's even somewhat sort of clean-ish, you need to move slower.
by dvanbramer88 » Wed Jun 20, 2012 10:41 am
by dvanbramer88 » Wed Jun 20, 2012 10:53 am
I was using primarily 3/32 rods. I also have, and used a few 5/64 rods.
by bartonmd » Wed Jun 20, 2012 11:04 am
by dvanbramer88 » Wed Jun 20, 2012 11:10 am
Yes, it is 3/32. My mistake. The reason i said ideal penetration, On the back side of where i was welding, you could see the bead line.
by bartonmd » Wed Jun 20, 2012 11:18 am
by dvanbramer88 » Wed Jun 20, 2012 3:48 pm
I manned up and welded 3 of the four corners. I made myself learn how to hold an arc at lower heat, about 45 amps, and worked very slow to fill the gaps. I made 2 passes inside and 2 passes outside. It worked good. The fourth gap was very wide and i used the piece of angle iron and welded all around, inside and out. It looks a lot stronger.
The piece of angle is the front right corner. My welds are as ugly as sin, but I am confident in the skid plate. I made it myself in my own backyard with relatively basic tools. I'm proud of it.
painting it back up. I remembered a drain hole.
and here is my reinforcements for in front of the oil pan. (I finished that weld on the right hand piece of angle, the gap was wide because it warped from the heat and the way the clamp was holding it, i made a shim and slid it under to fill the gab and just welded over the seams.)
by bartonmd » Wed Jun 20, 2012 4:03 pm
For what it's doing, I'm sure it'll be alright. I'm not going to lie. It looks really, really porosity-filled-booger-welded, but you'd be surprised how well even the nastiest booger-weld holds up if you don't stress it 100%. Hell, the mud-bogger guys in FL would call you down there to weld their suspension and stacked frames up, beause your welds look better than theirs do, and their stuff mostly stays together... Would I tow a trailer with a hitch that was welded like that? No, and I'm sure you wouldn't, either. It's probably fine for what it is, though.
ETA: The other thing about the porosity is, how old are those rods, and where were they stored??? Moisture in the air soaks into the coating on the rods (that turns into the slag), and after they get a certain % of moisture in them, it degrades how much inertion it can give around the weld, causing porosity. Make sure your rods are either:
1. new
2. Stored in the refrigerator
3. Stored in an air-tight electrode holder
by dvanbramer88 » Wed Jun 20, 2012 4:11 pm
I'm not going to lie, i weld like crap, HAHA. But for all intents and purposes, It will certainly work better than the factory plastic "skid."
And it only cost me a $7 box of rods. And I wouldn't trust anything structural with welds like that either, But i highly doubt that it will get sheared off by a rock.
But i do appreciate all the advice and encouragement.
by dvanbramer88 » Wed Jun 20, 2012 4:14 pm
by The Roadie » Wed Jun 20, 2012 4:17 pm
by dvanbramer88 » Wed Jun 20, 2012 4:21 pm
by bartonmd » Wed Jun 20, 2012 4:37 pm
by The Roadie » Wed Jun 20, 2012 4:51 pm
I've pried 1/2" rocks OUT of the gouges they made in the pyramid of Mike's #1 prototype aluminum plate (now on DirtyBacon's truck). Since then I upgraded to his steel version, and feel like I am wearing an armored jock strap. Homemade is fine, but as long as you know it's there to make noise to get your attention when you hit a rock at slow speed, and not to come crashing down off a 12" ledge onto it. Just have realistic expectations. You should see the FRAME dents on DirtyBacon's and my trucks, and then you'd understand better the level of threat out there we're trying to survive.
We also scrape our bellies enough to see the benefit of rock washers or welded rings to protect the mounting bolt heads, which you might not need unless you go and commit a lot of scrapeage.
by dvanbramer88 » Wed Jun 20, 2012 4:59 pm
by fishsticks » Wed Jun 20, 2012 7:58 pm
by navigator » Wed Jun 20, 2012 9:35 pm
Hi Dave, I plan to build one at some point. When I complete mine we can compete for ugliest welds!
Return to Fab Work
