Hard to answer this one fully.
Basically, you want to be prepared for anything that could break on the vehicle? The thing to keep in mind isn't what can fail... it's what is most likely to fail, how bad is that failure, and how far away you are from help.
The most basic repair-related items you could carry are:
-fuses (including a megafuse)
-multimeter
-accessible fire extinguisher
-a leak-repair kit (
http://www.dual-star.com/index2/Service ... 0Putty.htm)
-spare tire/tire repair kit
This will allow you to fix or stop most of the most common and potential catastrophes you may encounter, and allow you to at least limp back to a road. You can't fix most of the big issues on a trail, but the goal is just to get back to a location where you can get a tow.
Remember to just bring your common sense. For instance, if you destroy a front CV shaft, just remove it and continue. At least you'll be able to drive using the rear axle.
