offroadTB.com • View topic - How to press out the front lower shock mount bushing?
by mikekey » Sun Jan 12, 2014 5:52 pm
My searches here, GMT and the OS haven't resulted in much. Closest I've come to this is v7guy's post (using wrong search terms??), but I need a photo or some directions.
I have a a master ball joint kit, heat source and wrench, but so far the two times I've tried pushing this out it squeezes down the pops back out. Maybe I'm pressing it out in the wrong direction?? Anyone whose done this before have advice or a picture of how you setup your tools.
Or do I need to take this over to my father in laws 20 ton shop press to get it out.
by Moots1288 » Sun Jan 12, 2014 7:13 pm
by v7guy » Sun Jan 12, 2014 7:24 pm
In short, you need a press of some sort. You can burn em out, heat up the shell red/orange hot and then pound it out with minimal effort. But pressing the new one in requires more room than the ball joint press allows.
by mikekey » Sun Jan 12, 2014 7:32 pm
Ah, crapola. Thanks guys. I was kind of hoping I could take them out tonight, oh well.
by Trail X » Mon Jan 13, 2014 1:20 pm
You're supposed to press on the sleeve, right? not the stud. I'm not sure what you were doing exactly Mike.
And I'm moving this to suspension section.
by Aries » Mon Jan 13, 2014 1:32 pm
Aries
by mikekey » Mon Jan 13, 2014 1:34 pm
by Trail X » Mon Jan 13, 2014 1:53 pm
You might be able to just use a BFH on the install, provided you have the right size collar to press on the outer sleeve of the bushing.
You might also be able to pop the new stud out of the new bushing, press in the bushing and sleeve with the kit, then pop the stud back into the bushing. They have to install the stud into the bushing somehow, and I'm betting it's just pressed in there. I can't see them injection molding the bushing around the stud.
by Moots1288 » Mon Jan 13, 2014 2:05 pm
by mikekey » Mon Jan 13, 2014 4:08 pm
Yeah, that would be a lot of hammering.
by DirtyBacon04 » Mon Jan 13, 2014 6:42 pm
just buy a new LCA... call it a day
by mikekey » Mon Jan 13, 2014 6:51 pm
by Moots1288 » Mon Jan 13, 2014 7:10 pm
Exactly. I'm piecing together my mevotech arms with moog posts
by Aries » Mon Jan 13, 2014 7:50 pm
Aries
by v7guy » Thu Jan 16, 2014 2:47 am
I know the stock bushings seem to be bonded to the metal, so pressing the replacement bushing out may ruin it.
Concerning the mevotech arms, I replaced my bushings and balljoints a good 6 months or more before Matt and he's already had to replace the balljoints and needs to replace the bushings. Despite the extra work, replacing the bushings may be the way to go
