by Trail X » Mon Jan 13, 2014 1:34 pm
Correct Dustin 06+ there are dual VSSs on the rear axle shafts.
There are two on the back of the transfer case, one is the rear propshaft speed sensor, which outputs to the TCCM, the other outputs to the PCM/ABS. I know Mario (Gordinho80) had an issue with his rear VSSs recently, you might be able to find some information from him about where it's located exactly.
