offroadTB.com • View topic - Its time for a V8
Its time for a V8
by Zero » Mon Jan 25, 2010 1:13 pm
SO, as you can tell by my thread title, I think it is getting to be about that time that I start looking into an engine swap.
What i would like to do is drop in the 5.3l LH6. For a few reasons....1. The v8 engine in the EXT truck is supposed to get around 2mpg more then the inline 6 I currently have just because you dont have to drive the engine as hard to more the extra weight. This is even more true now that I have the big tires put on, and carry more weight on a regular basis. I started with a truck that was underpowered, and after some mods, and some camping gear, and passengers......the 6cyl just isnt cutting it for me.
Another thing to consider, I have a 2005 4.2l which was made before the revised 2006 6cyl was released which among other changes received a bump in power.
I would prefer to find an LH6 engine out of a trailblazer EXT because I assume it will make mounting, and plugging in sensors less of a problem.
If anyone can send me any links to someone who has done this swap, comments, or know right away of a few new parts I will need....PLEASE SPEAK UP!
I need to build up as much info as possible so I can buy the right parts the 1st time.
thanx
Z
by Philberto » Mon Jan 25, 2010 4:35 pm
I'll be looking on with bated breath... Been thinking of a swap myself, though I'd be looking at a L99 (AFM motor from Camaro) or L76 (6.0L motor from newer Avalanches), probably L76 (VortecMax). I know you may have issues with communication between the ECM and BCM, and may want to talk to Pcm4less to find out what can be done about that. Otherwise, I'm sure you can tweak your tranny to handle the power... those trannies have ben built to handle much more in Camaros... Best of luck.
by bartonmd » Mon Jan 25, 2010 5:05 pm
Been covered pretty extensively on Trailvoy... Nobody's done it because it's a bad idea, given that you can buy a SWB V8 for less than the difference in money that a swap costs, and have no time in it...
I have a SWB V8, and have done some looking at the I6 and V8 TBs...
- The engine mounts differently, so you'll need the V8 engine mounts.
- Because the engine is shorter, but still has to have the mechanical fan in the same place, the transmission and T-case are moved forward with the engine. This is only a big deal because the welded in transmission mount crossmember needs to be about 3" farther forward for the V8.
- The front drive shaft is shorter on the V8 (can come from donor EXT)
- The rear drive shaft is longer on the V8 (would have to have yours lengthened by ~3" or get one from a SWB V8)
- Computers won't talk... I6 uses a PCM, while the V8 uses an ECM and a seperate controller for the transmission.
- Spring rates change
- Radiator changes
- Rear axle out of EXT or SWB V8
You'd be time and money ahead to take the aftermarket stuff off of yours, sell it, and buy an '06-'08 SWB V8 to start with...
If you don't already have at LEAST 4.11 gears, preferrably 4.56 gears, and a PCM tune with all the T/M taken out, you're not to the point of making the V8 decision yet... The I6 has plenty of power. Spin it. That's what it's built for... If it wasn't made to spin, it wouldn't have 4 valves/cylinder, DOHC, and VVT...
FYI, the V8 gets about the same, or slightly less than the average I6 does... As shown in the "corrected" EPA numbers, as well... Your engine theory is wrong... The harder a gasoline engine works (while staying in closed loop control), the more effecient it is... The more open the throttle is, the less vacuum the engine is pulling, the better the volumeteric effeciency is... There was a VE/gas mileage/tire thread on either here or the other site, where James and I both explain the whole thing, so I'm not doing it again...
by The Roadie » Mon Jan 25, 2010 5:21 pm
Personally, I agree with Mike. Until you have 4.11 gears, you ARE strangling the performance of any engine you put in, and any tune you put on top of it. Save the engine swap money for camping gear and gadgets. :poke:
by bgwolfpack » Mon Jan 25, 2010 6:10 pm
Zero, put the stock tires back on and get the mileage you want along with more power. It may look stupid but it will get the results and wouldn't cost a dime.
by Zero » Mon Jan 25, 2010 10:14 pm
Thanx for all of your inputs. I will have to take a look around and see what I can get into. otherwise I will look into a gear change.
by Zero » Tue Jan 26, 2010 12:11 pm
Would you guys say it would be better worth my time and money to replace the 2005 6cyl I have with an 06 or 07? I believe they received updated heads, a bump in power, and a few other goodies. Am i correct?
by Philberto » Tue Jan 26, 2010 1:01 pm
I'd say you'd be better off just changing the head (IIRC that's the major difference between the two engines). Have you tried a PCM4Less tune yet? I'm going to be sending mine in for a tune I bought back last Labor Day, so I'll let you know the results.
by bgwolfpack » Tue Jan 26, 2010 1:10 pm
by Zero » Tue Jan 26, 2010 1:25 pm
by bgwolfpack » Tue Jan 26, 2010 1:35 pm
Great subjects, both this and the SS brakes, but shouldn't they be in the Discussion thread instead of Fab work? My understanding was this is for completed work.
by Trail X » Tue Jan 26, 2010 1:41 pm
by Zero » Tue Jan 26, 2010 1:49 pm
I was refering to people who crack their cast manifolds when doing high water crossings.
I guess it will be off to the dealer then if I need a tech tool. I want to check though. If they go in to fix just the CC, will that in anyway lead to me losing my tune?
by Philberto » Tue Jan 26, 2010 2:00 pm
Speedo I can live without... better gas mileage = more money = more trips offroading. I don't really use my CC either, but since I work at a dealer, I could always play around with the Tech2 and see what's up.
by Zero » Tue Jan 26, 2010 2:03 pm
by HARDTRAILZ » Tue Jan 26, 2010 2:05 pm
fwiw...my cc never quit working and they got my speedo right on. I have no complaints about the pcmforless experience. Better shifts, mpg and drivability.
by The Roadie » Tue Jan 26, 2010 3:35 pm
by HARDTRAILZ » Tue Jan 26, 2010 3:42 pm
I would venture to say that it was not the water crossing that did it then. It would seem coincidence that it broke during a water crossing if no one else has had that issue and you can not replicate it.
by bartonmd » Tue Jan 26, 2010 3:54 pm
by Trail X » Tue Jan 26, 2010 4:15 pm
