offroadTB.com • View topic - New guy from VA
New guy from VA
by greenway53 » Wed Dec 04, 2013 9:24 pm
Hello to all, My name is Logan. I'm a college student who is finally starting my slow build of my '06 TrailBlazer LS EXT, which I love and have never had any regrets about getting it (Her name is Sheila). I have not done much modification to my TB other than a few cosmetic changes and installing a flow master. In the coming months I am finally getting some A/T tires followed up with either a suspension lift or a body lift. Can't wait to share the build with y'all!
Beginning Product
Take away the traditional family look
Start of the blackout
Continuance of the blackout
How she sits today
greenway53
by ErikSS » Wed Dec 04, 2013 9:28 pm
Welcome!
by greenway53 » Wed Dec 04, 2013 9:29 pm
Ah shucks I meant to put "New guy from VA" not "BA" ....
greenway53
by TBYODA » Wed Dec 04, 2013 9:33 pm
by greenway53 » Wed Dec 04, 2013 9:36 pm
greenway53
by mikekey » Wed Dec 04, 2013 9:47 pm
Welcome to the site !
by djthumper » Wed Dec 04, 2013 10:19 pm
Welcome!
by Trail X » Wed Dec 04, 2013 11:07 pm
You're from my stomping grounds! I'm over here in the Salem area.
Welcome to the site. What sort of thoughts do you have for your truck? Interested in hitting some trails sometime?
by jonbo2002 » Thu Dec 05, 2013 7:17 am
Welcome, You're probably going to want to do a lift before you go with A/T tires otherwise you're gonna end up having to use tires that are barely over stock size.
jonbo2002
by DirtyBacon04 » Thu Dec 05, 2013 8:08 am
Suspension before body (lift wise)
Good lookin truck, btw. I like the yellow caliper/black rim combo. You got a good start having an EXT, meaning you already have the 8.6" rear axle. I'm guessing you dont have a g80 (which is also a bonus, in my eyes). Easier to drop in a stronger, more effective, aftermarket locker. Whats your gear ratio? V8 or I6?
by Cable810 » Thu Dec 05, 2013 10:08 am
Welcome!!
by razorvan » Thu Dec 05, 2013 3:32 pm
razorvan
by greenway53 » Thu Dec 05, 2013 4:32 pm
greenway53
by greenway53 » Thu Dec 05, 2013 4:37 pm
greenway53
by navigator » Thu Dec 05, 2013 5:23 pm
Board member/vendor MarkMc sells both 2.5" and 3" kits that are well represented.
You can find his items at theliftmeister.com. You can also get your wheel spacers from him.
If you aren't in a hurry, you might find some front lifts hitting the classifieds soon as 10+ members just purchased Radflo coilovers and some of them are already getting installed. You would likely still have to figure out your options for lifting the rear.
by DirtyBacon04 » Thu Dec 05, 2013 5:55 pm
by Trail X » Thu Dec 05, 2013 7:12 pm
Be careful focusing too much on the looks. Form driven by function is a lot of what we are all about here. Where do you hunt? Is it public land around here?
I agree with what Bacon said about lifts, except I wouldn't discount BDS if you're looking for a 3" lift. It seems the bushing issue is helped a lot by not getting springs that are too stiff, and partly due to the recent production change at BDS to larger bushing washers.
by Diacom » Thu Dec 05, 2013 11:04 pm
What ever you chose, I'm sure it will turn out. Welcome
by DirtyBacon04 » Fri Dec 06, 2013 6:55 am
by v7guy » Fri Dec 06, 2013 11:27 am
The comments on gear ratio stem largely from transmission heat, you'll find that generally we discourage going above 32" tires with 3.42 gearing due to transmission temps getting out of control. With 3.73s and bigger it's not as big of a deal to do 33s or bigger.
I think that 33s are probably the best compromise on our platform without getting too crazy, assuming you have proper gearing for them. We seem to start breaking things pretty regularly with 35s and lockers. With that said, a lot of guys have had plenty of success with 35s and leaving the front diff open. Although wheel bearings have been occasionally mentioned as a frequent wear item (think every year or two).
We've had success using a trans cooler with a thermostat inline to keep temps on the transmission reasonable during wheeling. My buddy Moots was seeing excessive trans temps with 3.73s and 33s on occasion (and then overcooling during cool days without the thermostat).
