offroadTB.com • View topic - Rebuild or Replace
Rebuild or Replace
by Wahugg » Sat Nov 23, 2013 12:22 pm
Hey all,
I've had a small knock for a while now that always went away after a minute or so while warming up. However it now seems to take even longer to go away, and it's become more pronounced.
Would you guys rebuild the lower end or just throw in a used one?
Thanks
-Wahugg
Wahugg
by Aries » Sat Nov 23, 2013 1:48 pm
Aries
by v7guy » Sat Nov 23, 2013 11:23 pm
It depends on the price/mileage you can find a used motor with.
It also depends on how comfortable/willing you are to do the work.
It's kinda hard to make recommendations here.
by bartonmd » Sun Nov 24, 2013 10:09 am
Word from the tech guys at GM, third hand, is that the similar thing with the small blocks is a ring of carbon deposit at the top of the piston travel. When everything is cold, the rings tap on this ring of carbon, and make some noise. This goes away as it warms up and everything expands. They will last 300k like that. The trucks do.
Now, if you want to try and get rid of it, you could try a seafoam treatment where you suck it in a vac port until the engine dies, then let it AIT 20 min before starting again.
When the early north star v8s did this, the cure was, I shit you not, for the tech to drive the piss out of the car for 45 minutes, and burn the carbon out of the cylinders.
by HARDTRAILZ » Sun Nov 24, 2013 12:40 pm
I just looked at used motors due to a GMT thread and they run about 500 not 2000. I know different prices in different areas, but you may want to do some research.
I would drive it til it died if it is just noise and not performance being affected.
by Wahugg » Sun Nov 24, 2013 1:16 pm
Thanks for the advice.
Mike,
This could be my problem since the knock goes away completely once the motor has warmed up.
Kyle,
Thanks for the tip on price. Most of the ones around me tend to be ~650 depending on millage. I would just drive in till it blows, but 90% of my driving is over long distances to Michigan or Texas, and that would be a dreadful time for the motor to kick the bucket.
-Wahugg
Edit: I should mention that the knock is only present while under load while it's cold. If I just turned on the motor and left in Park, then there would be no knock. But the second I drop it into drive, it starts to make the knock noise that's dependent on rpm.
Wahugg
by Aries » Sun Nov 24, 2013 9:51 pm
Aries
by dvanbramer88 » Mon Nov 25, 2013 5:50 pm
I found this for you
"Problem : engine sounds like midget with hammer inside it .
Problem solved by : Mike
Solution : Took hammer away from midget."
by RyansTBLS » Mon Nov 25, 2013 8:36 pm
:lol: I love it!
RyansTBLS
by mikekey » Tue Nov 26, 2013 7:23 am
Put a 350 in it an win points for originality. Only been done once so far, and that show queen hasn't been seen in a few years.
by HARDTRAILZ » Tue Nov 26, 2013 7:29 am
by Aries » Tue Nov 26, 2013 11:41 am
Aries
by TBYODA » Tue Nov 26, 2013 2:02 pm
by bartonmd » Tue Nov 26, 2013 2:08 pm
by ErikSS » Tue Nov 26, 2013 2:11 pm
I know that movie.
by mikekey » Tue Nov 26, 2013 2:16 pm
by bartonmd » Tue Nov 26, 2013 3:01 pm
by Wahugg » Tue Nov 26, 2013 11:19 pm
After driving 700 miles through Michigan, the nock has become slightly audible even when the engine is fully warm. Looks like this may become a winter break project versus a summer project.
Right now my plans are to pick up another used 04 engine and slap it in there but.....
..... Depending on financials and how fast I can get this done, I've been thinking about taking out the 4l60E and putting in a 5 speed AR5 from a Colorado. I can source a custom fly wheel from a guy over at the Vortec4200 forums, and a H3 bell housing will allow me to bolt it up. The only issue I've run into is trying to figure out if our T case will bolt up.
-Wahugg
Wahugg
by Regulator1175 » Wed Nov 27, 2013 12:36 am
Wallace, if you need an experienced hand, and are willing to drive here for a weekend, I will be glad to help you with this swap. I imagine that I can get Hatchet, AJ, and Erik to come over for the weekend as well. The four of us did a motor swap on Hatchets truck recently, starting Friday night and had it fired up before lunch on Sunday.
by Diacom » Wed Nov 27, 2013 1:03 am
