by The Roadie » Thu Nov 14, 2013 12:13 pm
Look at the data stream with a scan tool if you can to see if the sender is sending the bad data, or if the gauge is lying more than its usual algorithm forces it to. Rare for the temp gauge stepper motor to fail before the speedo or the tach because those two see more rotational action than the temp gauge. The gauge should normally be welded at 210, straight up.
