offroadTB.com • View topic - Drop Trailer Hitch Ball Mount
by ErikSS » Sun Aug 04, 2013 2:44 pm
I use my TBSS to pull trailers. I own 2 and my brother owns 3. Between them, they range from 300-7,000lbs and use all 3 common ball sizes. Of coarse, the tongues are also all at different heights.
So, what's worked well for people? I felt NO need for antisway nor load leveling with the stock SS suspension. With the lifted height and the Z71 spring (instead of air bags) I'm not sure. I did pull one around 4,500 last week. It was ok... but not great.
Anyone try this yet?
http://www.etrailer.com/Merchant2/graph ... 0_1000.jpg
by bartonmd » Sun Aug 04, 2013 3:00 pm
That will make it worse. Anything you do to give the trailer more leverage will make it worse. (more leverage, meaning the distance from the ball to the rear axle) Try this:
http://www.etrailer.com/Ball-Mounts/Hid ... 80412.html
by The Roadie » Sun Aug 04, 2013 3:06 pm
It would also be best to get modify the one (I assume you have only one) trailer that's demanding the 1 7/8" ball. UHaul makes their couplers fit either size ball, and you'd think that the 1 7/8" ball size would just die from disuse except for those little $100 dump trailers that could be attached to the vehicles with zip ties in a pinch.
by djthumper » Sun Aug 04, 2013 3:23 pm
Here is the ball kit that I run and you can use with the one that Mike listed. http://www.etrailer.com/Balls/Convert-A-Ball/900b.html
by ErikSS » Sun Aug 04, 2013 3:57 pm
I've never needed anti sway bars. I hear they help a lot. Has anyone felt the need to use them behind a lifted TB? What about load distribution system?
Mike, that was my #2 choice. Thanks for reminding me about the leverage behind the rear axle. I think that had crossed my mind, but I'd forgot. The advantage of the tri ball is that I'd only need one. Disadvantage would be, it' harder on my trailer hitch (I've caught it moving against the frame within the bolt hols) and probably lessens the stability of the coupled unit. Pros and Cons! I suppose it depends on how often am I changing trailers, and how far/often/fast am I pulling the heavier ones.
by ErikSS » Sun Aug 04, 2013 4:00 pm
by The Roadie » Sun Aug 04, 2013 4:15 pm
by HARDTRAILZ » Mon Aug 05, 2013 8:48 am
I use the one mike shared without issue.
by ErikSS » Mon Aug 05, 2013 10:43 pm
What's the heaviest trailer anyone has pulled at highway speeds in a lifted Trailblazer???
by ErikSS » Mon Aug 05, 2013 10:45 pm
by Gordinho80 » Tue Aug 06, 2013 9:13 am
Mario -
by Shdwdrgn » Mon Sep 16, 2013 11:07 am
Shdwdrgn
Contributing Author
by Opeth » Mon Sep 16, 2013 6:23 pm
I pull my boat with a harbor freight drop hitch through my CBI tire carrier. Boat and trailer weight ~ 3600lbs. No issues.
by djthumper » Mon Sep 16, 2013 11:49 pm
by Shdwdrgn » Tue Sep 17, 2013 10:32 am
Shdwdrgn
Contributing Author
by ErikSS » Tue Sep 17, 2013 11:02 pm
by HARDTRAILZ » Tue Sep 17, 2013 11:10 pm
I need to find you a link to the one my dad has. Heavy duty and solid. Bout 100 but put my HF to shame.
by ErikSS » Tue Sep 17, 2013 11:16 pm
I've found a few. I had one for a while. It was my brothers. I was tired of his BS so I returned his trailer hitch and took my trailers home. lol
by Opeth » Wed Sep 18, 2013 8:09 pm
