offroadTB.com • View topic - A little wander since Lift, Locker, and New Tires
by BWGuy » Sat Jun 22, 2013 4:01 pm
Has anyone else experienced something like this:
When stock, the EXT felt perfectly stable regardless of road quality.
I put the 3" front 2" rear lift on, and didn't really notice much degradation of the ride quality or loss of stability.
Then I put in the PowerTrax No Slip, and it seemed as though the rear end started trying to steer the truck a little bit.
Then I replaced the rear 245/65/17s with 265/70/17 Guard Dogs, and now the truck is downright swervy when I run through the shallow ruts that the local log trucks make in our hot Mississippi roads. When I first had the tires mounted, I though maybe the shop hadn't aired them up much, so I put about 40 psi in them when I got home, but there's still a good bit of wander from the rear.
Has anybody else had similar experiences and been able to do anything to improve the situation?
BWGuy
by DirtyBacon04 » Sat Jun 22, 2013 4:04 pm
did you get an alignment after the lift?
by BWGuy » Sat Jun 22, 2013 4:06 pm
BWGuy
BWGuy
by DirtyBacon04 » Sat Jun 22, 2013 4:15 pm
by BWGuy » Sat Jun 22, 2013 4:27 pm
BWGuy
by DirtyBacon04 » Sat Jun 22, 2013 5:52 pm
I'd say the unequal set up would be the cause of your problem. At least a contributing factor with not having an alignment. JD or Roadie could probably break down the mechanical forces at work in some weird formula that only they understand.
by BWGuy » Sat Jun 22, 2013 7:27 pm
I was hoping that was the case... that having the rear as much higher than the front as it is right now might be upsetting things a bit as far as the truck wanting to go in a straight line.
Imagining the absurd extreme of this where the truck is basically standing on its nose and the front edges of the front tires, I'd think there'd be a very strong tendency for the wheels to flop either to the right or left rather than staying straight.
Hopefully I'll get the Dogs mounted on the front on Tuesday and be able to report a much improved handling situation.
Thanks.
BWGuy
by v7guy » Sun Jun 23, 2013 9:51 am
get 4 tires of the same size on it and get it aligned, make sure you get a printout with the alignment on it. Then if things are still off we'll go from there.
With the combo you got, it could be any one of the things you mentioned, or all of them. Until you make an effort to get it right you should expect it to be wrong.
by dvanbramer88 » Sun Jun 23, 2013 6:36 pm
by HARDTRAILZ » Mon Jun 24, 2013 1:35 pm
It needs duct tape........
by DirtyBacon04 » Mon Jun 24, 2013 3:02 pm
and/or WD-40
by BWGuy » Mon Jun 24, 2013 10:02 pm
BWGuy
by v7guy » Tue Jun 25, 2013 12:15 am
make sure you get it aligned, you'll wreck the tires pretty quick if you don't, doesn't matter if it feels ok or not
by djthumper » Tue Jun 25, 2013 12:48 am
by BWGuy » Tue Jun 25, 2013 5:58 pm
The EXT with new tires all around.
BWGuy
by ErikSS » Tue Jun 25, 2013 6:59 pm
by navigator » Wed Jun 26, 2013 8:26 am
when you get a chance, flip your city/state.
It will allow folks to search the member list and sort by location and then all those from MS will be grouped together.
