Curt Front Hitch - Trouble Fishing the Bolts
by Blazintrails03 » Sun May 05, 2013 11:03 am
Took a little time and had to enlist the help of my sister's 07 cause i didn't take before pictures.
Here you can see the "before and after". The hitch tucks up nice and tighter than I expected.
And now for some crappy protection pictures. Sorry I didn't feel like breaking out the jack to I did my best on my back under the 2 TB's
No hitch on the 07
And some semi protection now under the 03
Blazintrails03
by v7guy » Sun May 05, 2013 12:01 pm
Is there a way to flip that bolt around? It being the lowest point is going to end up being all sorts of bad if you ever need to take it off.
by Blazintrails03 » Sun May 05, 2013 12:07 pm
You know I thought the same thing but this hitch has been through Mike Barton, Roadie, and Navigator and you can see scratches where the hitch has rubbed stuff but that bolt had no damage. It has been hit and bent a hair but great condition none the less. I had actually thought about getting under there with a sawzall and cutting it flush
Blazintrails03
by The Roadie » Sun May 05, 2013 12:47 pm
I know each and every one of the scratches I put on that in my early 31" tire days. Before BDS lifts. While I still had a payment on the Roadiemobile. Getting nostalgic..... :coffee:
See how PRISTINE it was on Day 1.
by navigator » Sun May 05, 2013 5:14 pm
v7guy wrote:Is there a way to flip that bolt around? It being the lowest point is going to end up being all sorts of bad if you ever need to take it off.
I can't think of the correct term but the bolt head is inside the cross member tube with some kind of flat bar built into the bolt head so it will catch on the sides. If you turn it over, there is no way to tighten the nut.
by Blazintrails03 » Sun May 05, 2013 10:23 pm
The Roadie wrote:I know each and every one of the scratches I put on that in my early 31" tire days. Before BDS lifts. While I still had a payment on the Roadiemobile. Getting nostalgic..... :coffee:
Yeah definitely not that clean anymore at all. The Mike Barton autograph on the side is a nice touch though haha
Blazintrails03
by Blazintrails03 » Sun May 05, 2013 10:24 pm
You probably could make it happen but I imagine it would be difficult.
Blazintrails03
by Blazintrails03 » Sun May 05, 2013 10:28 pm
Roadie your picture reminded me. I haven't tried yet but did you ever have issues with your tires rubbing the 2 bolts on either side of the hitch. I'm planning on 31's max 32's
Blazintrails03
by The Roadie » Mon May 06, 2013 10:17 am
I cut off the excess boltage right after that pic.
by fishsticks » Tue May 07, 2013 2:19 pm
I think you're referring to a "blind bolt."
Mark uses them on the rear bumper brackets for his body lift.
by navigator » Tue May 07, 2013 3:38 pm
fishsticks wrote:I think you're referring to a "blind bolt."
works for me!
