by Conner299 » Mon Apr 08, 2013 12:21 pm
Body lift is something different. Suspension lift will give you ground clearance, and a body lift will give you tire clearance. Bumpers will still be in the same place, relative to the body, after a suspension lift. There are two body lifts out there. A 2", and a 3". I, personally, prefer the 2", in both looks and functionality. I only plan on up to 32" tires, so it will work well, when that time comes. The 3" would be optimal if you want to stuff 35's up in your wheel wells. And welcome to the site.
