Lift Advice
by 06MidnightBlue » Fri Mar 29, 2013 12:20 am
The Roadie wrote:
DirtyBacon04 wrote:I was happy with my BDS until now...
I thought you were as bullshit with BDS; They have a specific failure mode that's been pointed out as a problem for hard-core offroaders, and their "No Fine Print" warranty sucks donkey ass.
Point proven. Lol
06MidnightBlue
by fishsticks » Fri Mar 29, 2013 12:31 am
06MidnightBlue wrote:
The Roadie wrote:Perhaps you ARE a pavement puss after all.
I didn't know you had the ability to use foul language Roadie.
You've never seen the inside of the moderator forum...
by v7guy » Fri Mar 29, 2013 12:46 am
Looks like you already know what we're going to say
If you cheap out and get Marks lift you'll find it gives you a cheap bushing to replace, it's $10. Can't go wrong there... cause you will end up replacing the bushings if you use the truck much. With that said I would echo what the rest have said, just get the radflos. They're more money, but the lift is adjustable, you can rebuild them if I remember correctly and the ride is significantly better. As it stands the bilstiens aren't really enough damping for the springs I have and the weight hanging on the front end. I don't imagine it'll be any better with bigger tires. If they were around when I lifted I would of probably just got them. Hell, I still consider getting them from time to time. I've driven a truck with the radflos and the difference is pretty surprising. Just save the money and get the radflos, it's worth it.
by Cable810 » Fri Mar 29, 2013 9:21 am
Marks 3" Hd struts up front and the Bilstiens that Donny mentioned. But to do it once do the Radflos.
by 06MidnightBlue » Mon Apr 01, 2013 12:11 pm
fishsticks wrote:Buy Bilstein 5125 shocks for the rear, no white body (BDS, SkyJacker etc) shock even comes close
^^. This
06MidnightBlue
by Trail X » Mon Apr 01, 2013 12:50 pm
The Roadie wrote:Can you throw up a picture of your upper bushing, washer, and top nut? Perhaps you ARE a pavement puss after all. Or BDS had a bad batch of poly bushings and you got good ones.
Left and right attached. They have held up well... not sure what else to say about it.
by 06MidnightBlue » Mon Apr 01, 2013 1:54 pm
James, what springs are you running?
06MidnightBlue
by Trail X » Mon Apr 01, 2013 3:28 pm
87s
by NC_IslandRunner » Mon Apr 01, 2013 5:50 pm
Mine have been installed for 3.5yrs and look like James. I must have got some of the ones they accidentally made good also.
by mikekey » Mon Apr 01, 2013 5:57 pm
Maybe there is a connection. I'd be curious to know how old each of the ones that failed are. Mine where installed back in June or so I think.
by djthumper » Mon Apr 01, 2013 6:07 pm
I wouldn't just go by age but the springs that are being used...
by 06MidnightBlue » Mon Apr 01, 2013 7:41 pm
djthumper wrote:I wouldn't just go by age but the springs that are being used...
True. The added pressure by the spring can put extra stress on the mounts.
06MidnightBlue
by mikekey » Mon Apr 01, 2013 7:54 pm
I have stock springs. Can they possibly be adding more pressure than those with 88's and 89s?
by djthumper » Mon Apr 01, 2013 8:38 pm
Not likely but others have bumped up their spring sizes as well... So it would not hurt to add that to the data collected. Having a little extra data for analyst doesn't hurt.
by jonbo2002 » Tue Apr 02, 2013 12:34 pm
I might get kicked out of the room for this, but are you maybe over torquing the nut onto the bushing? I just know I am famous for over tightening things and it comming back to bite me later.
jonbo2002
by Trail X » Tue Apr 02, 2013 12:40 pm
If it's assembled properly you can't really over tighten them. There is a metal sleeve that limits how far you can tighten the top strut nut.
by jonbo2002 » Tue Apr 02, 2013 3:30 pm
JamesDowning wrote:If it's assembled properly you can't really over tighten them. There is a metal sleeve that limits how far you can tighten the top strut nut.
ok got ya sorry, I was just going off my own (Captain Distructo) problems I have made for myself with other thing. I haven't done Struts as of yet so I wasn't sure if this was the case.
jonbo2002
by navigator » Tue Apr 02, 2013 9:28 pm
I think in some cases folks have problems by not tightening the nuts enough.
