offroadTB.com • View topic - Starting things off. New springs and shock
by rz03LTZ » Tue Mar 19, 2013 2:20 pm
If desided to start things off by replacing my front 83 springs with new 87s and BDS shocks. Are the 87s still available or does Moog have a similar set?
From what I've read, the Z71 springs and shocks in back will be a bit too stiff for me. So I'd like to replace my rears with the 87 rear shock and spring equivalents. Any suggestion what those might be?
Then comes new rubber. In leaning toward BFG AT 265-65-17s
Then comes the BDS 3inch lift a little later.
In the future I'll look at spacers, armours and bigger tires.
So what am I missing?
rz03LTZ
by Moots1288 » Tue Mar 19, 2013 2:23 pm
I got 89s with bilsteins
by rz03LTZ » Tue Mar 19, 2013 2:27 pm
I'm worried the 89s would be too stiff. I'm not planning on a load of recovery equipment and a couple hundred pounds of bumpers and armour mush them down. This is a part time road warrior I'm building here.
rz03LTZ
by Moots1288 » Tue Mar 19, 2013 2:29 pm
Ahh I see I see
by DirtyBacon04 » Tue Mar 19, 2013 7:55 pm
Has BDS made a 3" lift now? I hope they fixed their design flaw with the upper bushing...
by DustinC1989 » Tue Mar 19, 2013 8:07 pm
DustinC1989
by rz03LTZ » Tue Mar 19, 2013 8:14 pm
OK. Good to know. Until now I hadn't read anything quite so negative about the BDS lift. I thought I'd try and avoid the CV issues with the 3inch lift. But I guess its go hard or go home.
rz03LTZ
by DustinC1989 » Tue Mar 19, 2013 8:22 pm
BDS has a poor bushing design and there "no fine print warranty"... has quite a bit of fine print...
All the problems I've read about CV's and the 3" lift have been people with the 3" lift AND bigger springs. And the ones I've seen that had only the lift had torn boots, can easily be fixed with silicone boots.
DustinC1989
by Opeth » Tue Mar 19, 2013 8:33 pm
by rz03LTZ » Tue Mar 19, 2013 8:47 pm
The radflo coil overs. Big bucks I don't have.
I thought I'd be able to liberate about $5,000 for this but guess what... Not any more.
The coil overs sounded stiffer than I'd like from what I've read.
OK let's explore that for a minute. I used to drive an 88 Chev Silverado with a stock suspension. Then I moved to the 'Big City" and sold it. How would the 89's, Z71's or the coil overs compare with that for ride?
rz03LTZ
by Moots1288 » Tue Mar 19, 2013 8:49 pm
I had the 89s with 2.5 lift in the front... They were stiff never had to much of a problem but as soon as I went with the 33s I topped out like crazy.. Right now I'm loving the radflo coilovers.. Great way to spend 1000$
by Moots1288 » Tue Mar 19, 2013 8:50 pm
The radflos are stiffer but the shocks are built for those springs so you don't top out.
by mikekey » Tue Mar 19, 2013 8:58 pm
by djthumper » Tue Mar 19, 2013 8:59 pm
If you go with the radflo's you can adjust the ride height and not have to get other springs, struts and deal with the swap out of those components. Get the Z71's and see how it sets. If you want it taller adjust it and get spacers for the rear. I get compliments all of the time when they see the turning radius of our rigs even with the lift. Just the other day I made a U-turn behind a Tahoe and turned within his radius that he followed me to see what I had done to do that.
If the radflo's were out when I lifted I would have saved up a little more to get them then to get a few of the other parts.
by DustinC1989 » Tue Mar 19, 2013 9:03 pm
Unless you are gonna have some weight on the front (Steel bumper, skids, etc) 89's might be a bit much.
$5000 is easily doable.
My current order list is
springs-15125885's (84's stock, hardly any lift and no lift after skid plate)
Marks 3" lift w/ 2" rear spacers
Z71 springs
Bilstein HD fronts
Bilstein 5125 rears
and that is WELL under 5k for the lift
difference with marks kit, if the bushing fails... its only $10 and can be picked up at almost any parts store. BDS... you have to order it from just them
DustinC1989
by DirtyBacon04 » Tue Mar 19, 2013 9:10 pm
Same thing happens to BDS. The problem is the disc on top of the bushing is too small and it cuts in to the rubber, eventually making it just fall off. Then the threads on the top of the shock just eat away at the spacer.
by Opeth » Tue Mar 19, 2013 9:19 pm
by Moots1288 » Tue Mar 19, 2013 9:25 pm
5k is pocket change... Says me... Never
by Opeth » Tue Mar 19, 2013 9:33 pm
by Moots1288 » Tue Mar 19, 2013 9:35 pm
