Fishsticks' Build - 2002 Chevrolet Trailblazer
These builds are capable of traveling some of the most difficult trails known to the GMT360 platform (4.5+ per our trail rating guide). This section includes our SAS builds.
by fishsticks » Fri Apr 02, 2010 3:09 am
Vehicle: 2002 Chevrolet TrailBlazer LTZ
    • Build Date: 5/03/01
    • All available factory options
    • Purchased used in 1/07, 44K miles for $14500
Click on Part Numbers for links.
Drivetrain Specs:
    Original:
    • 4.2L I6 - 270hp
    • Selectable 4WD
    • 4.10 axle ratio (RPO GT5)
    • Locking rear differential (RPO G80)
    Modifications:
    • 8.6" rear axle swap
    • 4.56 gear swap (Motive)
    • Powertrax No-Slip rear locker P/N 92-07863005
    • Powertrax LockRight front locker P/N 1935
    • ATP AWD splined disconnect replacement (rebuilt old one 3 times then cracked the housing)
    • EXT 13" front brake swap
Suspension Modifications:
    Front:
    Rear:
    • Tahoe rear coil springs
    • Bilstein 5125 10" travel 255/70 valved shocks
    • Rough Country P/N 289 .75" spacer (top of spring)
    • Removed rear swaybar
    • GR Fab 1" Longer Rear Control arms with rod ends.
    • Total rear suspension lift - 2.25"
Exterior Modifications:
    • MDB Fab steel radiator armor
    • MDB Fab steel oil pan skid plate
    • RAGE Powersports Roof Basket
    • Custom tube winch bumper
    • 2 Hella 700FF driving lights installed in steel bumper, wired to factory fog light switch
    • MarkMC 3" Body Lift
    • Trail Gear 78" Rock Sliders (shortened 4")
    • 1.3" wheel spacers
    • Wheels: 17x8 25mm offset American Racing ATX Trench (Black, 6x127mm bolt pattern)
    • Tires: 35x12.5x17 Treadwright Guard Dogs
Engine Modifications:
    • Resonator delete
    • Welded 2 chamber muffler
    • High flow catalytic converter
    • Spectre universal cone filter
    • PCM4Less tune (Shift Firmness:2, TM Reduction:1)
    • Kooks stainless steel headers
Interior Modifications:
Recovery Equipment:
    • Road Shock (AKA Harbor Freight) 8000lb winch, P/N 67576
    • Recovery straps
    • Tree saver strap
    • Shackles
    • 48" Hi-Lift Jack
    • Hi-Lift Lift Mate
    • Hi-Lift Offroad Base
    • Shovel
    • Axe
    • Fire Extinguisher
    • Wrenches, sockets, drivers and other tools in multiple (and redundant) sizes.
    • Spare parts: CV axle, ignition switch, fuses, relays, coolant hoses, accessory belt, control arms, coil pack, injector, PCM, fluids, others...
    • First Aid Kit
    • On Board Air
    • Survival supplies: Food, clothing, blankets, ignition sources, ammo etc.
Electrical Modifications:
    • Onstar delete
    • Bose delete
    • Pioneer DD AM/FM/CD/BT/USB head unit
    • Kenwood eXcelon 6.5"/1" component speakers (front door/dash) & 6.5" coaxial speakers (rear doors)
    • RE Audio RFX Dual 4Ohm VC 12" Sub in 18x18x8.5 custom box
    • Fosgate Prime 600.5 600W amp
    • Bluetooth ODB2 data receiver and Torque Android app
    • 5V USB aux power to glovebox (for powering up USB hard drive full of MP3s)
    • Uniden Pro520XL CB radio
    • 800W AC power inverter (mounted where OnStar control box used to be)
Current Projects:
Future Projects:
Current Pic:
Highest Trail Difficulty Completed: Black Diamond (ORTB Trail Rating Guide: About 4.5)
by fishsticks » Wed Apr 06, 2011 10:10 pm
Picture Timeline
12/08 - Stock
4/10
5/10
7/10
8/10
9/10 - Broken stock rear axle
11/10
1/11
3/11
by fishsticks » Sat Sep 03, 2011 1:45 am
9/2/2011 Update -
Added all the stuff I've been lazy and not adding lately.
Control arms, Treadwright tires, swingout tire carrier, etc etc
Plus more recent pic.
(More pics tomorrow!)
by fishsticks » Tue Oct 02, 2012 8:33 pm
10/2/12 - First update in over a year. Pics to come.
by fishsticks » Thu Apr 18, 2013 2:32 pm
4/2013 - Added Bilstein rear shocks, Kooks headers, lowered by about 2". Sold to another ORTB member.
Return to Extreme Offroad Builds
