offroadTB.com • View topic - MOD: Baja Rack - Roof Rack
by Trail X » Thu Aug 25, 2011 2:24 pm
by BSalty » Thu Aug 25, 2011 10:40 pm
:drool3: I love your truck. Between you and Gordinho80 I will be broke for several years.
Formerly known as CBRguy.
BSalty
by galacticfuzz » Fri Aug 26, 2011 9:02 pm
galacticfuzz
by mikekey » Sun Jul 22, 2012 11:00 am
by scottp8113 » Mon Jul 23, 2012 4:29 pm
I think he said at some point that it was part of a fence repair kit that he found at Lowes/Home Depot.
scottp8113
by Trail X » Mon Jul 23, 2012 7:26 pm
by NC_IslandRunner » Mon Jul 23, 2012 9:53 pm
by mikekey » Tue Jul 24, 2012 3:35 pm
by navigator » Tue Jul 24, 2012 4:08 pm
for my rack I took a round washer and cut two sides off of it to make it fit snug in the track.
I then used a bolt and tightened a nut down real tight on the washer so it wouldn't slip. The result is the washer sandwiched between the bolt head and nut. It fit in the track tight enough that it wouldn't turn and I could then stick it up through my roof rack and tighten down with another washer and nut. I've only had one issue with them because my washers weren't heavy enough but it proved the concept to me. Next go round is heavier washers.
by Diacom » Tue Jul 24, 2012 10:58 pm
by mikekey » Wed Jul 25, 2012 7:35 am
by Trail X » Wed Jul 25, 2012 8:33 am
Here I thought he was just being funny. Mike, I also go by JD... so if it helps you in the future, just use that.
by navigator » Wed Jul 25, 2012 8:51 am
but don't confuse JD with James Dub :-)
by Logger280 » Sun Mar 20, 2016 11:29 am
Trail X could you share where you got your front bumper and the rear spare tire holder?
Thanks
logger280
Logger280
by djthumper » Sun Mar 20, 2016 6:37 pm
His stuff is all one-off custom builds. Check out his build thread for more information.
by Trail X » Mon Mar 21, 2016 9:17 am
Haha, yeah. For better or worse, I sunk a lot of money into this truck. The front bumper was based on a TAG (they've been known by other names) bumper. The rear was custom from the ground up.
Front bumper details: viewtopic.php?f=9&t=9
Rear bumper details: viewtopic.php?f=9&t=1132
