offroadTB.com • View topic - Front Springs Moog 81114 or 89s ?
by snowmirage » Sun Jun 10, 2012 9:27 pm
I plan to rebuilt my front suspension to fix a minor issue soon, I will be replacing my rear springs with the ever popular Z71's as they have started to sag quite a bit.
I figured I might as well replace the sagging front springs while I'm at it.
I will soon have radiator and oil pan skids up front but a full front bumper is not going to happen anytime soon.
Any thoughts as to whether I should give the 15125889 springs a try, or the moog 81114 springs ? I think I have read nearly every thread I've found mentioning either, as you know there is little known about the moog springs and I don't recall finding anyone running the 89s with out additional weight on the front end.
From what I can gather the 89's may be far to stiff without the additional weight of a bumper / winch up front.
snowmirage
by v7guy » Mon Jun 11, 2012 7:59 am
by Trail X » Mon Jun 11, 2012 9:50 am
Tough call Brandon. I'd suggest winging it with the 89s I guess. We can always cut down some of the coil if you find your truck topping out all the time.
by navigator » Mon Jun 11, 2012 10:24 am
has anyone contacted Moog to see if they will send us the spring info?
by snowmirage » Mon Jun 11, 2012 8:23 pm
I found a few random places that mentioned the 81110 moog springs having a spring rate of 375
http://www.rockauto.com/dbphp/x,carcode ... pring.html
That puts them between the 85's and 86's according to my math
spring N/mm lb f/in
1 5.71
1 5.71
881 50 285.5
882 53 302.63
883 56 319.76
884 60 342.6
885 63 359.73
886 67 382.57
887 70 399.7
888 74 422.54
889 77 439.67
I would guess the 81114s are either the same or slightly stiffer.
I was searching around the other site and came across a comment from someone in the classified section
http://classifieds.trailvoy.com/showpro ... 5283&cat=4
"Fyi 89s without weight in the front will top out."
So that's a shame :( if its true
v7guy I read through your build thread and see you have them on there with the 3" lift, have you looked to see how much down travel you have? if any?
snowmirage
by snowmirage » Mon Jun 11, 2012 8:26 pm
O wait simple solution.... just swap in a V8 to add more weight to the front right? haha
snowmirage
by bartonmd » Tue Jun 12, 2012 5:59 am
The V8 is all aluminum And weighs the same as the I6... Stock front springs are the same...
Sent from my DROID RAZR using Tapatalk 2
by The Roadie » Tue Jun 12, 2012 11:02 am
by Gordinho80 » Tue Jun 12, 2012 11:22 am
I've considered selling my 88s to go with 89s... if you want to swap... let me know.
Mario -
by snowmirage » Tue Jun 12, 2012 7:15 pm
sending ya a PM
snowmirage
by snowmirage » Tue Jun 12, 2012 7:18 pm
snowmirage
by boog2006 » Tue Jun 12, 2012 10:41 pm
boog2006
by snowmirage » Tue Jun 12, 2012 11:59 pm
Logically that makes sense, but I think you would have to work out a way to convert the change in height at the fender to change in height at the spring
Could be wrong its late and I haven't given it much thought yet
snowmirage
by Trail X » Wed Jun 13, 2012 9:04 am
True Brandon, plus the lever arm effect of the LCA and angle of the strut further complicate the matter. Regardless, the resulting height change in the spring would likely be fairly minimal and difficult to measure accurately. Therefore the accuracy of the resulting spring rate would be fairly poor.
by v7guy » Wed Jun 13, 2012 9:14 am
I can check how much extension i have left on Friday. I never bothered since I knew right from the get go the shock would be topping out.
by snowmirage » Mon Jun 25, 2012 6:11 pm
After trying to make a decision over the last few weeks I finally took the plunge ordered the Moog 81114 springs
$45 each shipped on ebay can't beat that.
I'll be sure to take measurements and such before and after when I get a chance to get them installed
snowmirage
by v7guy » Mon Jun 25, 2012 7:50 pm
should probably read through this thread so you have a rough idea what you may be in for. viewtopic.php?f=15&t=3283
Doesn't appear there's much extension at all lol
My new shock just came in about an hour and a half ago.
by snowmirage » Mon Jun 25, 2012 9:42 pm
Way ahead of ya read it a few times actually
snowmirage
by snowmirage » Thu Jun 28, 2012 5:01 pm
Well looks like I screwed the pooch..... :wallbash:
So.... when I ordered these from ebay I'm 100% sure it said "spring" and not "springs"! So 1st off I now have 1 extra set... (at a very good price mind you $45 for a set of springs shipped?)
then I just to look why i was missing ~$45 from my account and it seems I double clicked something in the payment section on the 2nd auction and ended up with 3 sets of springs!
Guess I'll put them up in the for sale section hopefully someone can use them.
snowmirage
by fishsticks » Thu Jun 28, 2012 9:05 pm
Get me ID, OD and length measurements on those springs. I know a guy with a home fab buggy that MAY be able to use your two extra sets. He's been using (and flattening) XJ coils.
