airless tires
by drwfaulk » Tue Jan 24, 2012 11:30 pm
has anyone seen these in use before
Reason: Fixed Youtube link.
drwfaulk
by drwfaulk » Tue Jan 24, 2012 11:39 pm
if not its still cool, they might work well off road :safari:
drwfaulk
by Philberto » Tue Jan 24, 2012 11:59 pm
These have been in R&D hell for years. IIRC, the main obstacles have been high-speed issues and the weight of the whole assembly. They currently use them on some forklifts and low-speed vehicles, but they're not in production for automobiles yet.
by NC_IslandRunner » Wed Jan 25, 2012 12:40 am
I've seen them on forklifts. But that's all.
by rjpoog1989 » Wed Jan 25, 2012 12:55 am
that would be really cool if they started producing those for autos, I expect they would work well offroad.
Ryan
rjpoog1989
by NC_IslandRunner » Wed Jan 25, 2012 12:58 am
rjpoog1989 wrote:that would be really cool if they started producing those for autos, I expect they would work well offroad.
only downside is they can't be aired down to give you a bigger footprint, what you have is all you get.
by drwfaulk » Wed Jan 25, 2012 1:03 am
Or they could make the tread roll around the side so when they compress on a rock or something they get wider and less compression rate (softer)
drwfaulk
by NC_IslandRunner » Wed Jan 25, 2012 1:05 am
drwfaulk wrote:Or they could make the tread roll around the side so when they compress on a rock or something they get wider and less compression rate (softer)
That could work.
by v7guy » Wed Jan 25, 2012 2:02 am
I saw these for the first time a couple years back. Then they were seen in the road racing crowds.
Even if they work great, what happens offroad when those things start picking up mud, sticks, and debris.
by Rob93 » Wed Jan 25, 2012 2:17 am
v7guy wrote:I saw these for the first time a couple years back. Then they were seen in the road racing crowds.
:Iagree: Imagine they'll be a disaster caked in mud
Rob93
by chevycrew » Wed Jan 25, 2012 8:12 am
I know some guys who run them on bobcats, they hate them and want real tires back.
by DirtyBacon04 » Wed Jan 25, 2012 8:53 am
I dont like the lack of flexibility. I like having choices when I air down. I usually leave the front tires at a slightly higher psi than the rear. Thats just me, though.
by Trail X » Wed Jan 25, 2012 12:00 pm
I went to a small engineering presentation on them once. It's really cool, but does have limitations.
If I recall correctly (it's been like 7 years now), one of the big hopes of the tweel was army use, because they could supposedly handle IEDs better. Supposedly they would deflect pressure away from the wheel better than an aired tire. Not sure if that ever came to fruition for Michelin though.
by drwfaulk » Wed Jan 25, 2012 8:09 pm
DirtyBacon04 wrote:I dont like the lack of flexibility. I like having choices when I air down. I usually leave the front tires at a slightly higher psi than the rear. Thats just me, though.
they could make inserts to make it stiffer and make some removable to make it softer and as for the rocks and mud they could always put a flexible cover over the holes
drwfaulk
Return to Off Road Discussion
