bgwolfpack wrote:Donny, why not pull the steering rack out of a newer wreck and get the correct upgrade?
Because the 16mm TREs are still curved, the inners still have a ridiculously thin section at the ball joint, and I'm tired of replacing broken ones. For my mission, it's
not the correct upgrade. These are straight, have much less exposed thread area (the weak part), are a DREAM to adjust compared to ours, are cheaper, more readily available (turns out they fit ALL recent full size trucks and vans), and will dovetail nicely with my NEXT mod.
If I break standard full size TREs, it's only going to take out the inner, not the outer AND the inner like ours do. Also, I can order these:
To answer the other question, the bit is within 1 degree of the TRE taper. I ended up running a 1/2" bit down through from the top, then opened it up with a 9/16" bit. Then I ran a 5/8" bit down in stages and followed it with the tapered bit. I cut a little at a time and then test fit the outer TRE until I had good seating and no wiggling before tightening it down. The bottom 1/3rd of the hole required no resizing.
Some pics:
I tried to get a good shot showing the taper of the new hole...
Through from the top.
The whole thing.
I have it roughed in for alignment right now. I had to unbolt the camber plate and pry it outwards to get my tire to move back forward, so I'll need an alignment anyway. Also, my LCA bushings are shot.
I got the one side done today, I'll try and get the other one done tomorrow. I'll keep it on surface streets for a week or so and keep a sharp eye on everything for oddities.
