Gordinho's Rear Bumper Project
by Gordinho80 » Mon Oct 17, 2011 4:07 pm
Beads on the hitch were done with much better welder. The mounts are actually mounted through the bumper. So extraction points are solid angle bolted to the frame.
by bartonmd » Mon Oct 17, 2011 4:25 pm
Gordinho80 wrote:Beads on the hitch were done with much better welder. The mounts are actually mounted through the bumper. So extraction points are solid angle bolted to the frame.
OK, cool... None of the rest of the stuff reall matters, structurally, then... You could grind it flat, then flap disk it, then run some Bondo over to fill the pores, and paint over it...
Also, did you see my edit on the last page?
by Gordinho80 » Tue Oct 18, 2011 10:24 am
I designed the mounts this way so that they don't loose any strength for extraction purposes. 3/8" thick 3" angle, grade 8 bolts to frame. I think they will hold up well. Receiver welded front and rear using a Hobart 220v with gas. That thing ain't going anywhere!
EDIT: Thanks for the link, Mike... but the coupon code is not taking.
by Gordinho80 » Mon Oct 31, 2011 10:13 am
A few updates... been working on the swing arm and the hinge. I was originally going to do a spindle hinge, but after looking at double shear, I decided to make my own. Started with the top hinge bracket.
Then I notched the end of the arm and welded in the tube.
Added the first bend in the arm...
Added the back support as well as the side filler/support for the top hinge bracket.
I still need to drill out a the bottom hing bracket, thats why you see the bolt sticking up as much as it is. I'm using a 3/4" grade 5 bolt for mock up. Going to see how it holds up once its in place.
I also reinforced the inside of the bumper a little where the hinge sits. This adds some support for when the arm is open.
Its slow going, but its moving. Had a bit of an issue with the latch I ordered. I found one on Amazon for $20... so I ordered it...
This is what I found in my mailbox...
So needless to say, I need to return it and order a replacement that is not meant for model cars. I still can't believe this thing was $20!
by Trail X » Mon Oct 31, 2011 10:44 am
Looking good Mario. That double shear will be sweet once it's all set up.
by bgwolfpack » Mon Oct 31, 2011 1:18 pm
That's looking nice Mario! Bravo!
Will you be using a thrust bearing for the swing action on the hinge?
by fishsticks » Mon Oct 31, 2011 2:15 pm
That double shear hinge makes me want to cut my tire carrier apart right now and redo it. Mine has developed a sag when open.
by Gordinho80 » Mon Oct 31, 2011 2:16 pm
I'm using this design...
I just need to get the bushings. They are sitting in my Shopping Cart on McMaster... just need to make finalize my list before i place the order to combine shipping. For now, I've got a thin tube that just about fits perfectly which I'll be using as temporary bushing.
by Karo » Mon Oct 31, 2011 5:26 pm
That looks really impressive! What did you think it would weight finished?
Karo
by Gordinho80 » Mon Oct 31, 2011 6:16 pm
Thanks!
I think I weighed the 10' section of C at 80lbs. This is almost all 10' of it plus all the extra metal for the swing arm... I'm guessing close to 40-50lbs. Going to weigh it once its complete.
by NC_IslandRunner » Tue Nov 01, 2011 4:00 pm
That's looking great!
by Gordinho80 » Tue Nov 01, 2011 5:48 pm
Thanks. I went through 3 step bits to drill out the brackets.... but I have them drilled. I ruined my 3/4 bolt in the process, so I have to get another. With washer above and below the arm, it holds pretty well for not being tightened, almost no deflection.
by Gordinho80 » Thu Nov 03, 2011 11:22 pm
Couple of updates tonight...
by Trail X » Thu Nov 03, 2011 11:42 pm
That is looking GREAT!
by Nakashige » Fri Nov 04, 2011 12:36 am
i want one
Nakashige
Vendor
by djthumper » Fri Nov 04, 2011 3:23 am
Looks Nice!!!
by navigator » Fri Nov 04, 2011 6:30 am
looks almost ready to paint!
by janesy86 » Fri Nov 04, 2011 7:48 am
Nice work Mario!
by bartonmd » Fri Nov 04, 2011 8:05 am
That's working out pretty well! Good job!
by Gordinho80 » Fri Nov 04, 2011 10:05 am
Thank you, gentlemen. It is coming along very nicely.
I shot it with a quick rattle can and left it on the truck for the time being. I need to take measurements for the tire carrier, some braces, and maybe a couple of other things.
Return to Fab Work
