GM #15125887 on indefinite backorder
by djthumper » Fri Sep 23, 2011 6:25 pm
Other than Bill running the Icons, I believe Mike was the only one running 89s.
by fishsticks » Sat Sep 24, 2011 7:10 pm
I can't see 89's being a death sentence for suspension components. I ran my 88's with no armor/bumper/winch for quite awhile and the ride was firm, but not jarring. With my added weight, I can squish the 88s to the bumpstops without much trouble. A lot of the bumper/armor combos that people have on here are heavier than mine.
I think Mike's problems are isolated... and probably due to prior collision damage. I'd try the 89's if they were my only choice.
by v7guy » Mon Sep 26, 2011 4:41 am
well, i've been going back and forth on the 86s or 89s, kinda leanin towards sayin F it and tryin the 89s just to see what happens.
by Trail X » Mon Sep 26, 2011 4:26 pm
You can always cut half a coil off the top of the spring to keep from topping out all the time.
by v7guy » Tue Sep 27, 2011 1:41 am
JamesDowning wrote:You can always cut half a coil off the top of the spring to keep from topping out all the time.
that's kinda what I had in mind, I've seen it mentioned a couple times, but I haven't found anyone that's done it yet, I guess someone has to be the first. From what i've seen even with the 89s there shouldn't be any cv joint issues. I'm finding less and less reasons to not use the 89s.
I drove my firebird as a daily driver with rod ended suspension at every link and was fine with it and it has 650lb springs. So I don't think the ride will be too stiff with the 89s as long as I'm not topping out the shocks. Not quite an apple to orange comparison, but still. lol
by Trail X » Tue Sep 27, 2011 8:43 pm
The big question is what are you pairing the 89s with.
by MrSmithsTB » Tue Sep 27, 2011 8:51 pm
You could also use the 1.5" smaxx spacers inside the assembly instead of the full 2" that everyone else does. Or use no inside of strut spacers, only the extra shims. I would imagine that setup in front with only z71 rear springs would level out nicely and be able to handle some decent weight without sagging.
by navigator » Wed Sep 28, 2011 9:18 am
MrSmithsTB wrote:You could also use the 1.5" smaxx spacers inside the assembly instead of the full 2" that everyone else does. Or use no inside of strut spacers, only the extra shims. I would imagine that setup in front with only z71 rear springs would level out nicely and be able to handle some decent weight without sagging.
I guess that is one thought, I think Mike Peters is running Mark's ~3 inch lift. A 1.5 or 2 inch might not be so bad.
by v7guy » Thu Sep 29, 2011 2:42 am
JamesDowning wrote:The big question is what are you pairing the 89s with.
i've got marks 3" spacers sitting here, if necessary i can get the top spring spacer from rough country for the rear, but i think it's going to be in the ball park of level.
the guys that were using the 89s said things settle after a couple hundred miles and they didn't need to cut the spring. But i'm thinking I might anyway.
Fishsticks and hardtrailz didn't have a problem with the 88s and since the effective height between the 89s and 88s is less than an 1/8"' and the spring rate is only 3n/mm difference i have a hard time imagining it'll be a problem. Obviously it'll be underdamped and stiff, but i think most of us are in that camp.
I could of course be completely wrong.
by navigator » Thu Sep 29, 2011 8:36 am
Mike was thinking that his TB might have been in a previous accident and that something was tweaked that may have added to his situation. There is no proof but that is kind of where folks are leaning.
by Skidder » Fri Feb 03, 2012 7:48 pm
Just for grins, I called the local Chevy house about this part number...the parts guy was really shocked to find it wasn't available anywhere. His only suggestion was to hit up the salvage yards looking for 03 and newer TB, Envoys, and Rainiers.
Skidder
by djthumper » Fri Feb 03, 2012 8:29 pm
Good luck with that even. I don't think anyone has listed anything close to that on our vehicles.
by Philberto » Sun Feb 05, 2012 9:24 pm
I may have a source for as long as they have stock. Waiting for confirmation of stock before I send you guys over there.
by DirtyBacon04 » Sun Feb 05, 2012 9:36 pm
:bounce: :bounce: oooh ooh ooh!! DIBS!
by Philberto » Mon Feb 06, 2012 10:18 pm
Well, unfortunately my parts supplier doesn't have the 87 springs either. Sorry guys.
by NC_IslandRunner » Mon Feb 06, 2012 10:19 pm
Philberto wrote:Well, unfortunately my parts supplier doesn't have the 87 springs either. Sorry guys.
Damn! I was hoping they would but I think we talked about them before on here somewhere.
by djthumper » Mon Feb 06, 2012 11:22 pm
Tease! You got everyone worked up. :slap:
by Mudwheelin » Mon Feb 06, 2012 11:25 pm
Just saw this thread. We have lots. In canada boys! Called a local dealer at lunch...if people want them let me know.
Build Thread:
viewtopic.php?f=25&t=2349
Mudwheelin
by NC_IslandRunner » Mon Feb 06, 2012 11:36 pm
Found it! viewtopic.php?t=158&p=43979
1st post on page 9
by NC_IslandRunner » Mon Feb 06, 2012 11:38 pm
Mudwheelin wrote:Just saw this thread. We have lots. In canada boys! Called a local dealer at lunch...if people want them let me know.
Do they have a website?
