offroadTB.com • View topic - Need help, lift prep...
by Bigemergency » Wed Oct 28, 2009 12:54 am
I am preparing to install Mark's lift with a Z71 spring set and Bilstein HD struts and shocks. The rear shocks are the same size as Z71 Tahoe shocks. I ordered them because of the problems I have seen in the threads with Z71 stock shocks. Will I be able to install the Mark's kit rear spacers and the Z71 shocks and springs together. I have been cruising threads but I haven't found what I am looking for. Help please... :scratch:
Bigemergency
by The Roadie » Wed Oct 28, 2009 1:08 pm
The shocks that sometimes come from the Ebay vendors with Z71 springs are nothing special. Bilstein aftermarket ones are a bit underdamped for the springs, and also offer no extra articulation to go along with the lift.
What are you lifting it for - mud or rocks? Do you have a G80? Do you need more articulation?
I strongly recommend longer BDS shocks to match the springs. BDS specifies a couple of part numbers that are for straight trailvoy springs, but longer. But they helped me choose a part number meant for Suburbans that are a much better match, and also 2" longer than stock.
What was your exact question again? You said you already ordered the rear Bilsteins and you have the Tahoe Z71 shocks as well?
by irishboy02 » Wed Oct 28, 2009 7:51 pm
I dont get it :scratch:
Youv got everything you need...now slap it in!
2003 GMC Sierra z71
7" FTS lift
irishboy02
by foosh » Wed Oct 28, 2009 9:25 pm
Brendan i wouldn't be talking so much about just slapping it in if i were you... :finger:
RECAP:
You text me at 3 saying you have the back done
I get to your house at 7, and all you have is the old springs out of the back... :hissyfit:
At 9: we'll go to target afterwards
2 AM Finally Done :mechanic:
foosh
by Philberto » Wed Oct 28, 2009 9:38 pm
by irishboy02 » Thu Oct 29, 2009 12:29 am
2003 GMC Sierra z71
7" FTS lift
irishboy02
by Philberto » Thu Oct 29, 2009 1:16 am
Yeah, I didn't use power tools, and it took me 7 hours to do everything... and found out the next day that I'd installed one of my rear shocks upside down... that's what happens when you drag things into the night. I am convinced, however, that everything will work because I made the blood sacrifice to the DIY gods. And yes, torque everything up with blue loctite... will make your life much easier down the road, because I had to retorque everything a few times to get rid of the clunks and rattles until I tightened everything down. And don't forget to use your bottle jack to jam down the control arms in the front when you're putting the strut assembly back on... took me 20 minutes and two beers to figure that out. :cheers:
by irishboy02 » Thu Oct 29, 2009 1:52 am
Yeaa its a fun time. Took me 11, but thats cause me and Murphy are very, VERY good friends...one day im gonna find him :shoot:
2003 GMC Sierra z71
7" FTS lift
irishboy02
by Philberto » Thu Oct 29, 2009 2:14 am
