MDB Steel Bumpers...
Moderator: bartonmd
by MrSmithsTB » Sun Jul 24, 2011 9:51 pm
Wicked awesome!
by themightysteveo » Mon Jul 25, 2011 2:38 am
bartonmd wrote:Kyle came over today to help me put a brush guard on SteveO's bumper, and to help me tack up DJones' bumper; and we went ahead and bent up some tube for a light hanger / deer catcher on his bumper...
Mike, Kyle... You guys ROCK!! I have nothing to say :drool: Thank you, both of you for EVERYTHING (*ALL OF YOU*)
themightysteveo
by bartonmd » Mon Jul 25, 2011 8:31 am
Thanks, Steve! I sent you a picture of the brush guard welded onto your bumper... Or at least started... Still need to hack off the bottom part of it...
Thanks!
by steveroche » Mon Jul 25, 2011 11:43 am
Looks awesome, can't wait for my bumper to finally take shape...
What size tubing did you guys use for that deer catcher? I got some inch and a quarter for my bumper...wondering if you have something about the same size.
steveroche
by bartonmd » Mon Jul 25, 2011 12:08 pm
steveroche wrote:Looks awesome, can't wait for my bumper to finally take shape...
Thanks!
The main hoop is 1.75 x .120 HREW tubing, and the support pieces in the rear are 1.25" dia...
by steveroche » Mon Jul 25, 2011 12:17 pm
Hmmm I may have to make a trip back to home depot to make a return and get some larger tube...The 1.75 looks wide in person, but when I see it on the Kyle's bumper, it seems to be the perfect size...
steveroche
by bartonmd » Mon Jul 25, 2011 12:23 pm
steveroche wrote:Hmmm I may have to make a trip back to home depot to make a return and get some larger tube...The 1.75 looks wide in person, but when I see it on the Kyle's bumper, it seems to be the perfect size...
It really is a good size for this, IMO...
FWIW, I know you're using mechanical pipe, so I'll tell you that tube is measured in OD and pipe is measured in ID... So 1.75" pipe is more like 2" tube...
by DJones » Mon Jul 25, 2011 2:38 pm
bartonmd wrote:Kyle came over today to help me put a brush guard on SteeveO's bumper, and to help me tack up DJones' bumper; and we went ahead and bent up some tube for a light hanger / deer catcher on his bumper...
Cool! Let me know when it is ready and I'll come to pick it up. Then we'll need to plan a trip to the Badlands. :woot:
David
DJones
by steveroche » Mon Jul 25, 2011 3:22 pm
Good to know lol, perhaps some 1.5 will do the trick. I'll take a run over to home depot today after i get my tires rotated...
steveroche
by bartonmd » Mon Jul 25, 2011 4:14 pm
steveroche wrote:
bartonmd wrote:It really is a good size for this, IMO...
Depends on the "schedule"... Schedule 40 will be a smaller diameter than Schedule 80... You'll just have to measure ODs of the stuff you're looking at using...
by fishsticks » Fri Aug 12, 2011 2:15 am
The A53E pipe I've used from my local Home Depot is approximately .133 wall. So 1.5ID should net you just over 1.75OD.
by steveroche » Fri Aug 12, 2011 5:46 am
That is what I ended up getting. I like the size, it should work perfectly for my plan/ideas.
steveroche
by DirtyBacon04 » Sat Aug 13, 2011 12:34 am
I'll take one. Non-BL, please.
Thank you kindley.
:drool3:
I need one
Already got S/N 0001 oil pan skid plate from bill. Probably gonna buy his rad plate too... this bumper will complete the puzzle!
by bartonmd » Sat Aug 13, 2011 1:39 am
Sent you a PM...
Thanks,
by bartonmd » Mon Sep 05, 2011 6:56 pm
Ha! Finally got After 6 hours of head scratching, squinting, and holding my mouth just right, the first 3" body lift standard bumper brush guard is complete! It really came out better than I could have hoped! (never mind the tape measure sitting on the 2" receiver)
by The Roadie » Mon Sep 05, 2011 7:21 pm
You've got a computer helping design that multi-bend light hoop? Very artistic!
by bgwolfpack » Mon Sep 05, 2011 7:31 pm
Oh My! :drool:
Damn! You are good! :cheers:
by MrSmithsTB » Mon Sep 05, 2011 7:54 pm
:drool:
by bartonmd » Mon Sep 05, 2011 8:34 pm
The Roadie wrote:You've got a computer helping design that multi-bend light hoop? Very artistic!
eh... Yes and no... The main corner bend was the computer (Bend Tech Pro) telling me how long it had to be and where to do the bend... From the main bend, we tried to figure out how to get some room to the headlight from the tube... I designed the bumper to be close to the headlights for the best tight turning radius, but hadn't anticipated doing the tube thing to them... I had thought about just cutting the tube at a 70 degree angle, and cutting off the end, and sort of mitering a small transition piece in... I figured if I was going to miter something in, I might as well try and do a bend there, to at least make the cut angle doable... So we held it up there and marked the direction, then headed back into the garage and put like a 30 degree bend on the tube (until the die started to dig into the previous bend)... Turned out to be just enough...
by Regulator1175 » Mon Sep 05, 2011 10:56 pm
looks really good Mike. Of course there never was any doubt that it would turn out great.
Return to MDB Fabrication
