Loose Ground?
by Blackout » Wed Apr 27, 2011 12:48 pm
Does anyone know where this loose ground is supposed to go? Found it just dangling in the engine bay when I was messing around in there.
Blackout
by Gordinho80 » Wed Apr 27, 2011 12:50 pm
That's not a ground.
That line connects to your fuse block to give direct 12v + to the trailer harness. Used when your need constant + at the harness.
by Blackout » Wed Apr 27, 2011 12:55 pm
Even better. I don't know how it came loose. Thanks.
Blackout
by bgwolfpack » Wed Apr 27, 2011 12:58 pm
As far as I've seen and on mine, they are not hooked up when built only when needed by the owner.
by Gordinho80 » Wed Apr 27, 2011 1:00 pm
It didn't come loose, they are not hooked up when built.
by Blackout » Wed Apr 27, 2011 1:03 pm
Good deal, thanks.
I sort of figured that'd be the case and I'd end up looking like an idiot.
Blackout
by bgwolfpack » Wed Apr 27, 2011 1:15 pm
No, good question. :coffee:
A red wire is usually a positive lead. If not hooked up in a circuit it is typically not used or for an option not used on the vehicle.
by Blackout » Wed Apr 27, 2011 1:31 pm
Good point. I should have known that. Been sort of burned out from school lately so my brains sort of mush right now.
Blackout
by djthumper » Wed Apr 27, 2011 2:26 pm
by spacer » Thu Apr 28, 2011 3:39 am
Mmm. Applesauce.
:chef:
spacer
by Regulator1175 » Sat Apr 30, 2011 1:39 am
Is this the first documented case of this question being asked here?
by Blackout » Sat Apr 30, 2011 10:52 am
Believe so
Blackout
by The Roadie » Sat Apr 30, 2011 11:01 am
And to think I skipped the thread because of the title, not thinking it was the well-documented (but not here) "red ring lug" issue. :wallbash: Too late for a snarky reply now. :?
by Blackout » Sat Apr 30, 2011 11:03 am
Yeah. I definitely feel like an idiot. Do I get a pass since I don't frequent the OS? :thumleft:
Blackout
by The Roadie » Sat Apr 30, 2011 11:19 am
No, because for simple issues like this, you can SEARCH the OS without "frequenting" it. :slap:
Use Google and restrict the search to trailvoy: "red ring lug site:trailvoy.com"
Of course, it's not trivial to know that "red ring lug" is the most fruitful search phrase. So I guess you can stay. :lurk:
by bgwolfpack » Sat Apr 30, 2011 2:34 pm
The Roadie wrote: Too late for a snarky reply now. :?
It's never too late for The Roadie! :coffee2:
by irishboy02 » Mon May 02, 2011 4:57 pm
Future reference - if you do find yourself trailering and needing the full power, this line is not connected from the factory. When needed, this line is long enough to be pulled up and you mount it to the power lead to the fuse box right there. That allowes you to use the big circle trailer power thingy (yes, thats the proper technical term)
2003 GMC Sierra z71
7" FTS lift
irishboy02
by bgwolfpack » Mon May 02, 2011 5:16 pm
irishboy02 wrote: ...the big circle trailer power thingy (yes, thats the proper technical term)
Also known as a 9-Pin connector. :raspberry:
by irishboy02 » Mon May 02, 2011 5:47 pm
yea...9 pin...thats what i said.. :coffee:
2003 GMC Sierra z71
7" FTS lift
irishboy02
by The Roadie » Mon May 02, 2011 6:57 pm
9?
Indeed. :scratch:
