Finally breaking down and doing a body lift.
by MrSmithsTB » Tue Sep 07, 2010 10:44 pm
HARDTRAILZ wrote:I am using my steering extention from the 2 inch with the 3 inch...i believe they are the same.
That is good to know. May have to rig something to get up and running and then switch them out when he has extras.
by MrSmithsTB » Thu Sep 09, 2010 7:05 pm
Body lift blocks have arrived:
And this is what will become the steering extension over the weekend:
3/4" x 36" steel round bar. Draw some lines, grind some metal, and drill some holes and this will be as strong if not stronger than the production extensions. Going to have plenty left over. If I determine that it is totally safe, I won't be opposed to making a few extras.
by Blask3 » Fri Sep 10, 2010 7:52 am
Looks good. Waiting to find some cash then a body lift may be in the future. Just gotta wait and see.
Jim Blask
GIT-R-DONE
The only Lifted TB in the Valley
Blask3
by MrSmithsTB » Fri Sep 10, 2010 8:23 pm
It seems I need a stronger bit to drill the holes, but I've gotten the hard part finished in regards to the steering extension. Since the pipe I bought is the same size as the steering shaft, and the shaft itself it hollow, I ground down the rod to fit inside the shaft instead of outside. It seems to be very strong and I doubt there will be any problem with it. I know it is not the prettiest thing in the world, but it will be hidden.
by irishboy02 » Fri Sep 10, 2010 8:28 pm
Performance over aesthetics. Best of luck!
2003 GMC Sierra z71
7" FTS lift
irishboy02
by MrSmithsTB » Fri Sep 10, 2010 8:31 pm
irishboy02 wrote:Performance over aesthetics. Best of luck!
Thanks, Brendan. Doesn't look to bad, but I haven't don any finishing passes with the grinder. Waiting until all of the test fitting is done and then I'll clean it up a little and throw some paint on it. I may have to install this all this week. If not, I'm thinking about trying to get up to Central somewhere to get a little mod meet goin.
by Regulator1175 » Mon Sep 13, 2010 1:55 am
MrSmithsTB wrote:Body lift blocks have arrived:
Are those 3" blocks? I thought you were only doing 2".
by HARDTRAILZ » Mon Sep 13, 2010 8:12 am
They look like 2 to me.
by MrSmithsTB » Mon Sep 13, 2010 11:20 am
Only 2", but I got 36 so I can stack up to a 6" lift :gimp:
by Gordinho80 » Mon Sep 13, 2010 11:29 am
36 ???
Are we doing a body life on the gordin-mobile??? LOL
by MrSmithsTB » Mon Sep 13, 2010 12:23 pm
Haha. I only got 12. Just so you know, It's no nearly as hard to put together a BL as you think. As long as you are willing to fabricate some of your own parts.
by Zero » Wed Sep 15, 2010 11:56 pm
I cant wait to see this!
by MrSmithsTB » Thu Sep 16, 2010 12:09 am
Here's hoping it goes down sooner rather than later. Potentially having some expensive 4x4 issues and may just have to sell some extra stuff.
by fishsticks » Thu Sep 16, 2010 3:51 am
MrSmithsTB wrote:Here's hoping it goes down sooner rather than later. Potentially having some expensive 4x4 issues and may just have to sell some extra stuff.
I feel you on the expensive 4x4 issues.
by MrSmithsTB » Thu Sep 16, 2010 1:05 pm
fishsticks wrote:I feel you on the expensive 4x4 issues.
Maybe not as severe as yours, but I may be looking at a new transfer case... :hissyfit:
by fishsticks » Thu Sep 16, 2010 4:30 pm
What's your T-case not doing?
EDIT: Did a quick search on car-part.com. I don't know where in NJ you are but I see T-cases as low as $200 in your area. :cheers:
by MrSmithsTB » Thu Sep 16, 2010 5:16 pm
It's not keeping it's fluid. I have a feeling that it is only the output shaft seal, but just preparing for the worst. I degreased it this morning, and I'm going to check it before dark to see if I can pinpoint the leak.
Edit: We're good. Output shaft seal :friday:
by Gordinho80 » Thu Sep 16, 2010 6:53 pm
Regulator1175 wrote:Fastenal bolts:
1) Part number 35112 M12-1.75 x 240mm 10.9 DIN 931 Part Thrd Plain Hex
Cap Screw
2) Part number 0122040 M12-1.75 x 190mm 10.9 DIN 931 Part Thrd Plain
Hex Cap Screw
3) Part number 95234 1/2-13 x 10.5 Grade 5 Yellow Zinc Hex Cap Screw
These bolts are for the 3" body lift, right?  So 2" body lift would
require 1" shorter bolts....
(2) Part Number 35111 M12-1.75 x 220mm DIN 931 Class 10.9 Plain Cap Screw
(10) Part Number 0122039 M12-1.75 x 170mm DIN 931 Class 10.9 Plain Cap Screw
(2) Part Number 95232 1/2"-13 x 9-1/2" Yellow Zinc Finish SAE J429
Grade 5 Hex Cap Screw
by MrSmithsTB » Thu Sep 16, 2010 8:24 pm
The 2" bolt lengths are:
160mm X 10
200mm X 2
by Regulator1175 » Fri Sep 17, 2010 3:11 am
Cap Screw
Hex Cap Screw
You are correct, those are for the 3" body lift.
