Cardone CV Shaft
by irishboy02 » Wed Aug 25, 2010 3:20 am
fishsticks wrote:The nut is 35mm, and there's an irregularity on it so that it doesn't back out easily. It will fight the whole way off.
On the passenger side, I'd just pull the splined disconnect. When I rebuilt mine I pulled it and the axle as a unit and it was pretty easy to get the axle out of it once it was off the truck.
:wallbash:
I knew it was something lke that, its laying in my garage somewhere im just too lazy to run down and check
2003 GMC Sierra z71
7" FTS lift
irishboy02
by Trail X » Wed Aug 25, 2010 7:55 am
When you have the pass side out, throw some grease in there for good measure.
Also, check the needle bearings to see what state they are in.
by Jon A » Sun Nov 14, 2010 1:41 am
Has anybody investigated possible differences between the "round" tripod housings and the "triangular" tripod housings? It occurred to me recently that binding at extreme droop travel may be different between the two. I can do some testing but wanted to check to see if it was old news already before I did.
Jon A
by Trail X » Sun Nov 14, 2010 10:05 am
I have not looked into the differences, but I imagine the limits would have direct relation to the size of the inner tripod (a scribed OD for the 3 bearings).
However, I would doubt there are any big dimensional differences between the Select and the OEMs/A-1s... that would require engineering, and I'd imagine Cardone is mainly just a copy company.
