Maxing front suspension lift (split from UCA discussion)
by MrSmithsTB » Wed Aug 04, 2010 12:49 pm
I hope everyone is aware of that. Also, I feel bad talking about all of this spacer speculation in a thread that was supposed to highlight our ability to reverse the UCAs. That idea is awesome, but hopefully it doesn't get dragged down by all of this negative lift info.
by fishsticks » Wed Aug 04, 2010 12:51 pm
HARDTRAILZ wrote:
Is it bad that I left a guy a message on a 4.09 geared D44 last night? :coffee:
Out of what? I have an extra 44. Too bad you are not closer.
Looks like the CL ad is gone now... so it must be too. Was a front from an 84 Jeep Wagoneer, 61" length, driver side pumpkin. He wanted 200 for it...which is probably why it's gone already. :)
To answer your other Q... I haven't had any shimmy issues so far. I'm at about 3.5" of resting suspension lift. My first attempting gave me 4" but the CV angle was critical.
Reason: fixed the quote
by fishsticks » Wed Aug 04, 2010 12:53 pm
OregTrailBlazin wrote:
fishsticks wrote:A couple interesting things: First off, the Suspensionmaxx "1/2 inch" shims are actually only 3/8" thick. :hissyfit: Secondly, my UHMW, which I thought was only 3/8" thick, is actually 7/16" thick. Stacking it nets 7/8 instead of the original 3/4 I thought I'd get.
ried to move the motor when I turned the wheel by hand. No go.
You guys realize that the thickness of the spacer it self does not correlate to the amount of lift you will get....Right? A thinner spacer like a 3/8" will net about a 1/2"-5/8" on our truck. The strut is mounted closer to the pivot point on the lower control arm, so a little bit of movement there, is more exaggerated at the tire....
Sorry I wasn't clear... I called when I originally ordered and was told the shims were 1/2 inch... I'm aware of the way our suspension works like a lever.
by fishsticks » Wed Aug 04, 2010 12:55 pm
MrSmithsTB wrote:I hope everyone is aware of that. Also, I feel bad talking about all of this spacer speculation in a thread that was supposed to highlight our ability to reverse the UCAs. That idea is awesome, but hopefully it doesn't get dragged down by all of this negative lift info.
For me, reversing the UCAs was a means to an end... that end being more front lift.
by Gordinho80 » Wed Aug 04, 2010 12:56 pm
:hijack: This thread has been hi-jacked like no other... I'm not even sure where to begin to clean this up... :viking:
by HARDTRAILZ » Wed Aug 04, 2010 12:59 pm
[quote="fishsticks
Looks like the CL ad is gone now... so it must be too. Was a front from an 84 Jeep Wagoneer, 61" length, driver side pumpkin. He wanted 200 for it...which is probably why it's gone already. :quote]
You know we have about 66 inches from mounting surface to mounting surface from what regulator measured for me. 61 would have been pretty narrow
by fishsticks » Wed Aug 04, 2010 1:11 pm
Indeed....probably better that it went elsewhere.
by SteveTB03 » Wed Aug 04, 2010 1:28 pm
So where did you pick up the UHMW you used fishsticks?
Go Big & Go Broke
SteveTB03
by fishsticks » Wed Aug 04, 2010 1:32 pm
My garage produced it... honestly, I forget where I got half the things that are clogging up my garage.
by Philberto » Wed Aug 04, 2010 2:11 pm
Thread cleaned... not sure whether to split up SAS discussion yet, will keep an eye out.
Carry on.
by SteveTB03 » Sat Aug 07, 2010 7:04 am
Well I'm going to be heading over to IKEA to get some polyethylene chopping boards (made from UHMW) tomorrow at 10am then on Tuesday I will have to cut off the BDS bolts that are welded and add some more longer ones roughly an inch or so longer then it will be time to add a .75" pieces of cutting board to the strut.
The boards I found were black and were 3/8" thick so two of them will be good for me. Oh and ill be putting these two pieces on top of the BDS kit and under the markmc spacer I already have.
Go Big & Go Broke
SteveTB03
by SteveTB03 » Sat Aug 07, 2010 6:54 pm
Here's a pic of the chopping boards I got from IKEA today 3/8" thick. So I got 4 of them so I can start stacking these bad boys after I cut them to the size I want.
Go Big & Go Broke
SteveTB03
