offroadTB.com • View topic - Rear shock install HELP!!!!
by aaronrules » Thu May 20, 2010 9:58 am
So this is going to be a very noob question, but I can't wrap my brain around it. I am in the middle of installing my BDS 5500 series shocks since I figured it would easy...pretty much is easy...even without taking the TB off the ground, just got it sitting there on all fours.
Okay the question is, where do all the washers go? I have the rubber bushing in the shock, then on the top, I have two big washers on the outside of the bushing with the metal rod in the middle. My question is the bottom. It looks like the shock is going slide back and forth on the metal rod. Do I put the two smaller bushings/ spacers on the longer one? the kit only came with three washers also.
i have stared at the pics and instructions as well as searched EVERYWHERE here and the OS as well online, but I can't find either pictures or just a straight up answer. How do I put the bottom of shock onto the truck with the supplied spacers/washer?
Please excuse this question...I know it's probably elementary, but I work on A-10's not so much work on vehicles...please help my guys...the truck is sitting there with only one OEM shock installed on the rear...and I gotta go eat lunch with my boy today at his school!
aaronrules
by MrSmithsTB » Thu May 20, 2010 10:11 am
Can you throw up some pics of what you are talking about? From what I remember installing Mooseknuckles 9500s, the rubber bushings were all the same and slid in first. There should be two short sleeves and two long sleeves(the metal cylinders that slide into the bushing). We put the short sleeves up top and the long sleeves at the bottom and used the factory shock bolts and the install was done.
by aaronrules » Thu May 20, 2010 10:12 am
Looking at the BDS website for instrucions on how to install the 55619 shock, it shows that there are 4 washer...both of mine came with three
aaronrules
by fishsticks » Thu May 20, 2010 10:12 am
I wondered this too when I got mine...couldn't find a definitive answer.
I ended up with this.
Ring - Washer - Washer - Shock Bushing - Washer - Ring
...on the tube.
Zero problems so far.
by aaronrules » Thu May 20, 2010 10:23 am
I am idiot...cant figure out the picture posting crap! Trying...
http://www.flickr.com/photos/60573549@N00/4624437346
Admin Add:
Reason: Added picture
aaronrules
by aaronrules » Thu May 20, 2010 10:27 am
Well that link gets to the flickr that i posted the pics...nothing is tight...just threw it up to look at it. no washer or spacers installed at...i was going to let you guys look at it at see what you think....in a couple pics I moved the shock on the spacer on the bottom to show you what I am concered about.
aaronrules
by aaronrules » Thu May 20, 2010 10:31 am
aaronrules
by The Roadie » Thu May 20, 2010 10:33 am
If you didn't get the right hardware, the BDS guy is a vendor/member here and I'm SURE will make it right ASAP. We're much more open to vendors for functional offreaders than the greedy OS.
by aaronrules » Thu May 20, 2010 10:34 am
aaronrules
by fishsticks » Thu May 20, 2010 10:38 am
Interesting that I only got three washers as well. As I remember it I don't think there wasn't any more room for another washer either...
Hmmm...
by irishboy02 » Thu May 20, 2010 12:29 pm
My 9500s only have 3 - mooseknuckles came with 3 as well
2003 GMC Sierra z71
7" FTS lift
irishboy02
by Zero » Thu May 20, 2010 1:09 pm
i think you should do whatever you can to get that shock centered. also send a PM to our bds guy, he should be able to clarify things.
by bgwolfpack » Thu May 20, 2010 1:20 pm
Remember these are not made specifically for our trucks. Just a, this will work sorta deal to help us out and sell more shocks. There should be 4 washers per side and if we need to stretch the mount out a little, as Roadie did, than so be it. But my impression was these fit with the proper hardware not washers thrown in a kit.
by Zero » Thu May 20, 2010 1:58 pm
Please correct me if I am wrong, but isnt this guy installing a set of 5500 series BDS shocks? if so, then you are wrong. The BDS stuff is made for our trucks. Even specifically valved for our trucks. Unless I overlooked a post that stated he was using a random set of 5500.
by bgwolfpack » Thu May 20, 2010 2:07 pm
by aaronrules » Thu May 20, 2010 3:54 pm
Got it installed. Didn't use any washer on the top mount, just squeezed the mount basically onto the shock. And on the bottom I did all three washers and the two bushings. Drove it about 30 miles and don't see any apparent damage or moving...I would just feel better if there were washers for the top mount next to the bushings, and one more on the bottom like the roadie's...I might let it eat this way...but the PM is going to be sent to BDS rep right after I post this, just to see what the deal is.
aaronrules
by BDS Suspension » Thu May 20, 2010 4:34 pm
http://www.bds-suspension.com
Use it, Abuse it...that's what it's made for!
Best and Only "No Fine Print" Warranty in the business!
BDS Suspension
by aaronrules » Thu May 20, 2010 4:36 pm
aaronrules
by BDS Suspension » Thu May 20, 2010 4:43 pm
BDS Suspension
by Zero » Thu May 20, 2010 5:46 pm
Finally a company that stand behind their product and gives a damn when people need help.
