offroadTB.com • View topic - Somedudes Build - 2002 GMC Envoy SLT
by somedude » Fri May 24, 2019 12:58 pm
somedude
by somedude » Fri May 24, 2019 1:24 pm
Stock
somedude
by somedude » Fri May 24, 2019 1:29 pm
Lift blocks, shocks, and wheel spacers installed, waiting for new tires and alignment
somedude
by somedude » Tue May 28, 2019 6:20 pm
Front driver side strut showing ball joint clearance
Front passenger side strut showing ball joint clearance
Rear driver side air spring with lift block
Rear passenger side air spring with lift block
Rear driver side shock
Rear passenger side shock
Rear driver side wheel spacer, also replaced brakes and rotors
Rear passenger side wheel spacer, also replaced brakes and rotors
somedude
by somedude » Wed May 29, 2019 4:19 pm
somedude
by somedude » Wed May 29, 2019 5:15 pm
Went to my local pick-n-pull and found several vehicles with still okay condition roof cross bars. It was 50% off that day also, lucky me, so it cost me $16 CAD for both. I plan on supporting a roof top tent on the factory cross bars, it should be okay. I found that the weight capacity of the roof rack is 220lbs in the manual. Refer to section 2-62 at the url below. Not sure exactly if that means the cross bars can hold that amount, but, if you have 4, should be better!
Extra factory cross bars
somedude
by somedude » Tue Jun 04, 2019 12:32 am
Picked up a used Tepui Kukenam Sky 3 person tent. It was pretty easy to lift onto the roof rack with a second pair of hands. Wrenching up the mounting brackets took a little bit of time because the amount of room under the rack is limited but it wasn't too bad. Took out the tent for a camping trip and really liked it. The camp site was 3 hours away and I had no issue on the drive. I slept 2 nights and had no issues with tent. The tent felt solid on the roof rack.
Mounting
Mounting 2
Closed
Open
Open 2
Looking bigger than the other Envoy
Looking bigger than the other Envoy 2
somedude
Return to Mall Rated Builds
