offroadTB.com • View topic - Please direct me to the Aux Transcooler fittings OR line.
by clickscrazy » Tue Jul 11, 2017 9:16 am
Installing an Aux Trans Cooler.
I found the fitting for the line that goes into the Rad.
But what about avoiding cutting the line that goes into the trans OR at least using a compression fitting so I don't have to flare?
clickscrazy
by bartonmd » Sat Jul 15, 2017 10:41 pm
I just cut the line and used 3/8" compressions on it.
Though, if you've got the inline-6, the trans cooler lines are run in such a way that you can separate them at the quick-connect fittings on the passenger side frame and use this quick connect barb fitting to go into the female side.
https://www.amazon.com/gp/product/B000E ... UTF8&psc=1
by clickscrazy » Mon Jul 17, 2017 9:46 am
Do you mean you used brass 3/8 plumbing fittings?
clickscrazy
by bartonmd » Mon Jul 17, 2017 8:10 pm
Yes
by clickscrazy » Tue Jul 18, 2017 8:41 am
I picked up a double flaring tool. Figured I would try that first.
clickscrazy
by clickscrazy » Tue Jul 18, 2017 6:58 pm
This job is now down. Double flaring set was $22. I felt like it was simpler with less connections.
I just cut the lines and flared them. I tried to take one off to drain a little fluid....was VERY difficult to remove the hose from the flared line.
clickscrazy
