2004 TB EXT with 4.2, 4L60E, 4x4, and recent 4.10 axle swap and tune. All systems have been great...although over the last few months, I had a "shudder" in my TCC, when locked, that was causing it to unlock... Kept cycling like that but nothing really special. Replaced the valve body a few months back, and it has been running VERY well. No DTC's typically....although every once in a while, Id get the "transmission part slipping" code....probably my shuddering TCC.
So today, Im driving to the Sox game to meet a coworker from out of state, expressway with the cruise set to 70ish with AC on. Out of the blue, tach goes wild....and bounces up to 4,500rpm. I immediately kill the cruise, and manually rev the motor....feels like neutral. OK....shift into neutral, back to drive....nothing. Drop down to third....nothing. Sooooo...I coast over to the side of the expressway. Come to a stop, put it in reverse....yup, nothing. Engine runs fine, no issues, AC nice and cold..... No puddles under the trans, no holes in the case, nothing. Seems like my tans decided to just float away. I did notice today there were 2-3 times....where the car made a metallic "sawing/rubbing" kind of sound, like when you used to put a trading card on the spokes of your bicycle. Only for a few seconds each time.....with no other symptoms. Oh, and when the car was idling on the side of the expressway, there was a "slight" bit of the same sound, but constant. When I started it up after the tow home....that noise was gone, but I still have nothing. Pulled the dipstick, and the fluid was perfect...no glittery metal particles in it or burned smell.
Soooo.....any ideas? Anyone want to take a wager on what part died? I have not been able, or will, run a pressure test. I will try to get under it later this week to see if the convertor is rotating with the engine. In the Helms manual, the only thing losing ALL gears diagnoses to is that the convertor isnt bolted on. Anyone shear off the convertor bolts? Strip the input shaft splines? Sun gear shell strip the splines?
This is a weird one as there was literally no boom, weird noises, blown lines, slipping in gear....nothing. It just stopped transmitting power through it.
I didnt make it to the game either
, Dude your swaping the trans in a TB'er not going over Niagara Falls in a barrel. Not only does it sound like you have the concept of R&R a transmission but it sounds like you have the ability to get it right.
