by v7guy » Mon Feb 01, 2016 8:49 am
Generally speaking, after the clips are removed GM uses double sided tape to attach the trim pieces to the body. Typically guys use some fishing line to cut through the glue between the body and trim (in a sawing/pulling motion, occasionally a plastic scraper is needed to get it started... Fishing line and plastic scraper keep you from damaging the paint) and then something like goo gone or another adhesive remover to peel off the remaining adhesive left on the body. It's easier to do on a hot summer day when it's softer, but you can have success with a heat gun or hair dryer too.
To get the bulk of what's left after the trim is removed use a finger or thumb to push on it and roll it up off the body, a glove can help keep you from getting blisters if your hands are callused up good.
