offroadTB.com • View topic - Rear Lift - Upper Arm to Sway Bar Link Clearance
by HawkeyeC25 » Tue Jan 05, 2016 6:10 pm
Hey all,
After doing my rear lift with the 2.5" pucks AND Z71 springs, I noticed that there is very little clearance between the upper trailing arm and the sway bar link. In fact, when I installed the new shocks, the arms were actually resting on the links and I had to compress the shocks by almost and inch. Which means the axle wants to sag further before bottoming out the shock, but instead will rest the upper arms on the sway bar link.
Anybody run into this? I'm not seeing anything hitting on normal driving, but I'm worried about when I go off road with more articulation.
Thoughts?
HawkeyeC25
by Anthony Hernandez » Tue Jan 05, 2016 8:54 pm
Meh, just get rid of your rear sway bar all together...
by HawkeyeC25 » Tue Jan 05, 2016 9:20 pm
I saw a lot on this forum about doing that, but I've got a longer length and more weight with the EXT. Not sure I'm ready to do that yet. But it still didn't answer my question of whether or not people have this issue as well?
HawkeyeC25
by Aries » Tue Jan 05, 2016 10:56 pm
Aries
by HawkeyeC25 » Thu Jan 07, 2016 9:36 pm
Any other opinions? Is everyone just pulling their rear sway bar? I might try it since I have the z71 springs back there.
Does anyone still have theirs in and run into any interference with the upper arm and sway bar link?
HawkeyeC25
by KingBird » Fri Jan 08, 2016 12:24 am
My rear sway bar is still in, but I've disconnected it on one side. Yes things are close back there but that hasn't stopped it from operating the way it should. Before I disconnected the rear sway bar, I was able to run around like normal. It had good flex too. Thing is, I have very little extra body roll with it disconnected with lift blocks, normal Tahoe springs, and Tahoe Z71 shocks.
My advice would be to disconnect the rear bar and drive it around for a week. If you don't miss it, pull it out. I'll be doing that once we thaw out.
KingBird
by v7guy » Fri Jan 08, 2016 8:52 am
Generally speaking, most guys just pull the rear sway bar, the front makes the biggest difference, and even so, there's a large number of guys that have pulled the front too.
by HARDTRAILZ » Fri Jan 08, 2016 2:56 pm
Pretty sure mine hit before removal. Seem to remember dings in the stock arms before swapping them out.
by hilljb » Fri Jan 08, 2016 7:51 pm
I don't have an EXT, so I can't speak to what is the norm there, but I definitely have a bit more room than what's in your photos. And, I'm using 2.5" spacers plus Z71 springs.
Mine is a 2003, and it seems like the rear sway bar was redesigned somewhere in that year. Before that redesign, the bar bushings bolted into place. After, and I've read that it is a more welded/permanent mount that needs to be cut. Mine is the bolt-on design. That may have an impact on clearance.
I was trying to maintain the links, but found that they wear very quickly and make a ton of noise. So, about half a year after replacing them, I just took both the front and back bars off completely. I was worried that the sway would be bad when going around turns. It's noticeable, but not as bad as I expected. I'm glad I took those things off. The truck is much quieter over bumps now too.
hilljb
by HawkeyeC25 » Sun Jan 10, 2016 12:19 am
I also have the bolt on rear sway bar bushings so it would be easy to remove completely.
So I just drove down the road and drove through a ditch. You can see that I definitely hit the upper arm on the sway bar link. The rear left tire isn't completely off the ground here, but it did start to spin with little to no pedal input (G80 locker works!!)
A couple things to note with my truck that may be a little different than yours hilljb, I'm currently running no spare, nothing inside the truck, and my springs were new moog springs for a z71 - not sure if they still need to settle in with some weight. Either way, this is a little too close for me - I think I might just pull the sway bar and see if the HD Bilstiens, Z71 springs, and front sway bar are enough to prevent body roll.
HawkeyeC25
by Brendon » Thu Jan 14, 2016 1:35 am
I'm a total Newbie so I apologize in advance if this doesn't make sense. In all the reading I have been doing to plan my build it seems that once the rear gets lifted 3" or so that the standard length shocks aren't long enough. Could this have anything to do with it?
Brendon
by Brendon » Thu Jan 14, 2016 1:57 am
Brendon
by HawkeyeC25 » Thu Jan 14, 2016 2:00 am
Thanks for chiming in (I'm fairly new here as well), but no. I would actually prefer the shock to bottom out first (which it would on the stock suspension). But since it's lifted, in order to not always bottom out the shock, one must install longer travel shocks in order to have more down travel (which I did). However, it's this added down travel that now allows the upper arm to drop far enough to hit the sway bar link.
HawkeyeC25
by HawkeyeC25 » Thu Jan 14, 2016 2:04 am
HawkeyeC25
by Brendon » Sat Jan 16, 2016 2:36 am
Brendon
by HawkeyeC25 » Sat Jan 16, 2016 6:08 pm
HawkeyeC25
by Brendon » Tue Jan 19, 2016 4:13 am
Brendon
