offroadTB.com • View topic - Do I need to change?
by eschy1990 » Thu Jul 23, 2015 2:33 am
Is there a need to change the shocks, struts, and springs when I lift my tb? I don't plan on hard trail riding. I don't tow anything and I'm only getting a brush guard for the front and rear. I'm going with marks 3" lift spacers and adaptors and I'm thinking of 265/70/17 tires can I leave the rest stock?
Follow me on Facebook
or on Youtube
eschy1990
by maricard » Thu Jul 23, 2015 7:14 am
You can stay stock. I did it some times. But if you add rear lift spacer your stock rear shocks won't be enough long.
Ludwig Mies van der Rohe
maricard
by eschy1990 » Thu Jul 23, 2015 8:15 am
Ahhhhh ok gotcha I didn't even think about that...do the 07-12 z71 shocks give you enough length?
or on Youtube
eschy1990
by maricard » Thu Jul 23, 2015 8:41 am
You can read this topic to help you : viewtopic.php?t=20
maricard
by eschy1990 » Thu Jul 23, 2015 1:24 pm
I have already multiple times thanks! just shows the bds and blistein shocks unless your hinting at that's what I need to use...and those part numbers from 2009 are hard to find...I called GM with the part number for the 87 springs and he didn't know what I was talking about or how to look up the new part number...yikes...
or on Youtube
eschy1990
by TBYODA » Thu Jul 23, 2015 4:21 pm
A lot of us run the skyjack rear shocks 8030 IIRC, check out my build. IMHO if your gonna pull everything apart might as well get new parts. At least struts and shocks. Look for the 87 springs on eBay or gmpartsdirect.com
by moose1 » Thu Jul 23, 2015 9:20 pm
i would think it all depends on how many miles you have on the current set up. Also how much your willing to spend. it's a perfect time to take care of issues while it's tore down.
moose1
by eschy1990 » Thu Jul 23, 2015 10:35 pm
Right now I've got the belltech 2/3 lowering kit on it that I've had since November of last year I've gotten into storm chasing here in Tulsa and am a skywarn storm spotter and am on the spotter network...lowered looks cool but for chasing is not ideal...my buddy is buying my lowering kit for his 06 tb so I can lift mine so it will be more useful.
or on Youtube
eschy1990
by HeavyChevy4200 » Fri Jul 24, 2015 5:32 pm
You can keep the springs. Do you have the original struts and shocks? Mileage? I would swap the front struts if you're going to go through the trouble of taking it all apart. You could leave the rear shocks and see how it rides. If it bothers you then its only a couple bolts to change them out.
HeavyChevy4200
by TBYODA » Sat Jul 25, 2015 12:21 am
Does not the belltech 2/3 lowering kit have smaller front springs? Unless you still have your stock springs your going have to get new springs or swap with your buddy. Also if you add a the 2" rear spring spacer from Mark's kit to the rear with or with out the Z71 springs which BTW add about 1" of lift. You will top out the rear shocks because they will be to short for add spacer. Don't cheap out on you build. Read, plan, save, build. I highly suggest reading though a lot of build threads, a lot us put links to the parts we buy to help out others. Good luck.
by eschy1990 » Sat Jul 25, 2015 12:45 am
or on Youtube
eschy1990
