offroadTB.com • View topic - What is this for?..rubbing at full turn.
by escapepilot » Tue Jun 02, 2015 2:35 pm
I'm getting some rubbing at full lock on both sides. Does anyone know why there is this little tumor looking projection here? I haven't had a chance to get underneath and see what is there, but from the outside, looks like a BFH will eliminate the rubbing.
escapepilot
by Moots1288 » Tue Jun 02, 2015 3:56 pm
Are you talking about the subframe?
by escapepilot » Tue Jun 02, 2015 4:11 pm
escapepilot
by v7guy » Tue Jun 02, 2015 8:29 pm
That hole is commonly used to tie down the truck on a tow truck with some J hooks, can also use it to pull the vehicle around. It shouldn't stick out.
Get a hammer and bang it in.
by escapepilot » Wed Jun 03, 2015 8:40 am
escapepilot
by HARDTRAILZ » Wed Jun 03, 2015 10:56 am
It sticks out factory, so it should stick out. However, it should not cause any issue to bang it flat except that you need to seal the metal up in and out if you dont want potential for rust there after.
by escapepilot » Thu Jun 04, 2015 9:31 am
I banged on one side last night then hit it w/ some coating. I didn't think of the backside, so I'll be sure to spray that also. I figured I'd try one side and see if it makes much difference. I surprised I haven't seen anyone else mention this area. Surely it has happened before.
escapepilot
by Trail X » Thu Jun 04, 2015 12:14 pm
My tires rub there once in a blue moon. I try not to full lock it though, in general.
by HARDTRAILZ » Thu Jun 04, 2015 3:14 pm
I get rubbing there, but only when parking. Never heard it on the trail. Yet to have it cause any real issue. Figure its a non-issue. Rather have that steering stop and less chance of serious frame rust than beat it in.
I did think about tossing 2 inch spacers up front to eliminate the rub.
by Regulator1175 » Sun Jun 07, 2015 11:53 pm
If I remember correctly, The notches are there for a jack / jack stand location.
by v7guy » Mon Jun 08, 2015 12:22 am
Strange, my 02 envoy doesn't stick out there, it's just a hole.
by HARDTRAILZ » Mon Jun 08, 2015 8:42 am
That is strange. I think they have been bumped out on every one of this platform I have wrenched on. Wonder if it was a change after the first year like some of the other oddities.
by Trail X » Mon Jun 08, 2015 2:04 pm
Could be a spot that they used for picking up the chassis on the assembly line and ferrying it through the factory. I can see that sort of stuff changing a bit over time as the manufacturing engineers try to improve their efficiency.
by escapepilot » Thu Oct 01, 2015 4:13 pm
Update: With the help of a large, heavy tool, the protrusions have been recessed and I no longer have rubbing issues at full lock.
escapepilot
