Cut Bumper for Ground Clearance
by foosh » Sun Mar 21, 2010 11:54 pm
Well it wasn't my nice bumper that was on the tb, it was one that i bought from Bobbyblaze when he sold his tb. I simply primed and painted with a close duplicolor 5 or 6 coats with 4or 5 coats of clear, still have to 800 grit wet sand it to give it that shine.
(12.51 KiB) Downloaded 625 times
(21.32 KiB) Downloaded 625 times
(22.26 KiB) Downloaded 625 times
foosh
by foosh » Mon Mar 22, 2010 2:18 pm
Haha anyways this bumper will start to get alot more cut up once the skid plate and other new front end accessories com into play... for a scrap bumper that i don't have to worry about ruining, its worth the couple bucks. (of course its a cheap replacement bumper that doesn't fit quite right, but its close enough)
foosh
by HARDTRAILZ » Mon Mar 22, 2010 2:43 pm
foosh wrote:Haha anyways this bumper will start to get alot more cut up once the skid plate and other new front end accessories com into play... for a scrap bumper that i don't have to worry about ruining, its worth the couple bucks. (of course its a cheap replacement bumper that doesn't fit quite right, but its close enough)
Mike's radiator skid means no bumper cutting for stock or 3 inch body....
by foosh » Mon Mar 22, 2010 2:59 pm
I like mikes quite a bit, but it might be modded... Not even sure how my idea will work, so i'm holding off on the cutting for now.
foosh
by Trail X » Mon Mar 22, 2010 3:36 pm
The thread was cleaned per the OP's request.
Tom, I thought about doing that once... looks pretty good, but if I were you, I'd cut the ends of the bumper a little higher... right now it's tapering down and doesn't really look right... maybe if it tapered upwards it may look better AND give more clearance.
by foosh » Mon Mar 22, 2010 7:32 pm
As I said JD, there will be more cutting, but yeah i figured thats gonna need to be done plus alot of black plastic trimming.
foosh
by KE7WOX » Mon Mar 22, 2010 10:22 pm
Probably with the right equipment and expertise, this can be done
KE7WOX
by foosh » Mon Mar 22, 2010 11:45 pm
I plan on running my fog lights still though... for a while at least.
foosh
by KE7WOX » Tue Mar 23, 2010 1:42 pm
You can try to cut the grey plastic in the center at the same height you cut the sides
KE7WOX
by Gordinho80 » Tue Mar 23, 2010 2:29 pm
Cutting the grey part along the same line would give it teeth... wouldn't look right.
by bgwolfpack » Tue Mar 23, 2010 3:07 pm
Gordinho80 wrote:Cutting the grey part along the same line would give it teeth... wouldn't look right.
I agree. I cut mine and stopped where you did Foosh. Not perfect but looks better than having the teeth. And I must say it's utilitarian.
by Gordinho80 » Tue Mar 23, 2010 3:14 pm
I've considered doing this mod as well. Maybe if I come across a cheap bumper skin, I'll give it a shot...
There is a skin listed on the OS, but seller is in IN. Too far for me...
by bgwolfpack » Tue Mar 23, 2010 3:55 pm
Why hesitate? But also, why would you do it? Is it the looks you like or the fact you can attemped a tougher trail or shoping cart? :poke:
I like the way Foosh and mine and others have turned out.
Here is a better pick of mine.
(93.36 KiB) Downloaded 552 times
Cut the rear also.
by Gordinho80 » Tue Mar 23, 2010 4:17 pm
HA... not for looks...
I say "considered" as I've yet to have issues with clearance, even during TECORE and everything we ran into there. I even still have the OEM wind deflector under the bumper. Picking the right line has helped...
by 05ls_soldier » Tue Mar 23, 2010 8:49 pm
I'm on this bandwagon too, although, I still need to clean up my cut a little!
Save the gold, I'm investing in lead!
If guns are outlawed, only outlaws will have guns!
MY BUILD THREAD
05ls_soldier
by foosh » Tue Mar 23, 2010 9:16 pm
Gordinho80 wrote:HA... not for looks...
Mario, if you've never hit your front bumper you haven't wheeled enough or hard enough, i got this one to tear up because i was afraid of riping the other one off, which has been a close call a buncha times. These bumpers are really bad in mud if your backing up they just grab it all, i'm hoping this will help with some more cutting.
foosh
by Philberto » Tue Mar 23, 2010 10:34 pm
I haven't had my bumper cover in so long, I've forgotten what it looks like... thanks for showing me so I can remember :poke:
by foosh » Tue Mar 23, 2010 11:40 pm
Its this big thing that typically matches the trucks color that without it makes the truck look incomplete... haha just busting your balls. :awesome:
foosh
by Gordinho80 » Wed Mar 24, 2010 10:38 am
bgwolfpack wrote:Here is a better pick of mine.
Cut the rear also.
:hijack:
That is the cleanest, shiniest, looking off-road vehicle I've ever seen.... :poke:
by Trail X » Wed Mar 24, 2010 10:40 am
Goodness... this thread has turned into a nuclear arms race... everyone's talking about how big their proverbial dick is but no one is "getting lucky".
:safe:
