offroadTB.com • View topic - 2002 on one tons
2002 on one tons
by Fastonthetrack » Fri Mar 20, 2015 10:22 pm
heres my 02 TB on one ton running gear. Dana60 front 14 bolt rear with 5.38 gears and spools. She sits up on 52" ford 1/2 ton leaf springs front and rear and 39.5 iroks. all stock drive train. running a toyota IFS steering box and rock ram hydro ram for assist and 14" bilsteins.
Fastonthetrack
by Cable810 » Fri Mar 20, 2015 10:50 pm
2002 seems to be pretty popular for SAS :lol: Looks good man!
by Fastonthetrack » Sat Mar 21, 2015 1:41 am
Thanks dude. still some work to iron out.
Fastonthetrack
by navigator » Sat Mar 21, 2015 9:00 am
yeah, nice looking ride!
by v7guy » Sat Mar 21, 2015 10:40 am
looks spiffy! I dig it!
Why didn't you completely weld the steering box plate to the frame? What's up with the lack of weld on the pitman arm (looks like there needs to be a second bead ran on the top portion there)?
by Fastonthetrack » Sun Mar 22, 2015 12:19 am
The steering box plate will be welded more when I clean up the frame. The pitman arm something I'm testing. So far so good.
Fastonthetrack
by HARDTRAILZ » Sun Mar 22, 2015 9:09 am
Looks like fun!
by ErikSS » Sun Mar 22, 2015 1:54 pm
Very nice~! If you had to guess, how much do you think the parts for this swap costed you?
by Jrgunn5150 » Sun Mar 22, 2015 6:47 pm
Awesome
by Fastonthetrack » Tue Mar 24, 2015 12:21 am
Fastonthetrack
by Trail X » Wed Mar 25, 2015 1:59 pm
How much lift does it have over stock? Looks higher than it needs to be. Looks like you could remove the spring blocks and likely be happier. What are your plans for something like this? Do you do mud bogging? Or are there some gnarly trails around you where you're not very concerned about the high center of gravity? Thanks for sharing, I want to see more!
by Fastonthetrack » Wed Mar 25, 2015 4:42 pm
Fastonthetrack
by DirtRidinZ71 » Fri Mar 27, 2015 9:27 pm
Looks great! I have a few questions.
36" spring pad width d60?
How does the 4.2 like the 39.5 tires with 5.38 gears?
What t case are you running?
Do you have a pic of the oil pan clearance? Would pushing the axle more forward help? I have a 79 ford d60 so the diff is not offset as far.
What did you use for a steering shaft from the gear box to the factory shaft? Any pics?
I have been wanting to tear apart my 92 gmc truck and build a new family wheeler and set up about identical to this. With 39.5 irocs, 5.38 gears in a 79 ford d60 and 10.25 sterling, gm 52" front springs and 63" rear springs.
DirtRidinZ71
by Cable810 » Fri Mar 27, 2015 10:17 pm
He used the stock tcase and has a 241 ready to go in. He build looks a lot like what Steve and mike did.
by Fastonthetrack » Sun Mar 29, 2015 11:19 pm
Fastonthetrack
by Fastonthetrack » Sun Mar 29, 2015 11:22 pm
Oh and i am running a kingpin front end as well..
Fastonthetrack
by v7guy » Sun Mar 29, 2015 11:45 pm
How much compression would you gain with a rear sump pan?
I've always wondered how much it got in the way.
by Fastonthetrack » Mon Mar 30, 2015 12:01 am
well you dont ever want to put your leaf springs into a negative arch. soo if you bump stop them properly there is nothing to worry about either way.
Fastonthetrack
by Jrgunn5150 » Tue Mar 31, 2015 6:54 am
by ErikSS » Tue Mar 31, 2015 8:30 am
It sounds like this truck was built tall enough to not worry about the oil pan. Leaf springs have a reputation of loosing arch when compressed too far. They can, but you can replace or re-arch them also. They are generally not expensive.
