looking for advice on front shocks and springs
by eschy1990 » Sun Jan 11, 2015 3:45 pm
what shock/spring combo will get me close to the height of rear Z71 springs and Skyjacker N8030 shocks and Markmc 2" lift spacer? after searching i can't really find the best answer without spending $1000+ on the radflo's...and does anyone know exactly how much lift the rear Z71 springs and and Skyjackers will give you?
eschy1990
Name: Jeff Eschenbacher
by Moots1288 » Sun Jan 11, 2015 6:00 pm
I dont know.
by Opeth » Sun Jan 11, 2015 8:49 pm
I'll let you know if 88's and all mikes armor will make me sit level with the z71's and marks 2" lift come spring time
by v7guy » Mon Jan 12, 2015 12:53 am
It depends on a lot of factors. Even with the exact same combo yours might sit a bit different from someone else.
by eschy1990 » Mon Jan 12, 2015 2:30 am
Ok I'm thinking I'll go Z71 all around does skyjacker have a front shock that we can use?
eschy1990
by 02_chevy » Mon Jan 12, 2015 8:22 am
88'S on the front and z71's in the rear, thats what i run and my truck sits level
Only victory red TB I see on here lol
viewtopic.php?f=74&t=5101 <- My build
02_chevy
by v7guy » Mon Jan 12, 2015 9:25 am
Can't use z71s on the front, no idea on skyjackers for the front... most go with the bilstein hd.
by eschy1990 » Mon Jan 12, 2015 5:43 pm
Ok cool anyone have a part # and brand name for the 88's and the part # for the bilsrein's?
eschy1990
by Opeth » Mon Jan 12, 2015 7:44 pm
Is that a serious question?
by TBYODA » Mon Jan 12, 2015 8:11 pm
eschy1990 wrote:Ok cool anyone have a part # and brand name for the 88's and the part # for the bilsrein's?
Dude do some reading.
viewtopic.php?t=158
viewtopic.php?t=20
by v7guy » Tue Jan 13, 2015 12:58 am
Jeff, you'll find the vast majority of these questions are answered in the stickies in the forum. A good number of any other questions can be answered with a quick search or even a reply in an old topic. Generally speaking, we try not to rehash the stuff in the stickies in new threads.
You'll find the part numbers for the bilstein in the sticky Robert posted and an explanation that the 88 springs are the last two numbers of the gm part number for that particular spring. You'll find references that the 87 and 88 springs were out of production, last I heard GM had replenished the stock and they should be available.
by HARDTRAILZ » Tue Jan 13, 2015 1:09 am
Skyjacker N8030 give exactly ZERO lift.
by eschy1990 » Tue Jan 13, 2015 2:30 am
Ok guys I'll make sure to read to and explore every avenue before posting a question...thanks anyways guys.
eschy1990
by Opeth » Tue Jan 13, 2015 9:53 am
v7guy wrote:You'll find references that the 87 and 88 springs were out of production, last I heard GM had replenished the stock and they should be available.
I will vouch that the 88's are available, it took GM parts direct about two weeks to get them but are still out there. I ordered mine back in November I believe.
by kcb58h » Wed Jan 21, 2015 7:55 pm
You should do it the other way around. Get a LM 3" spacer + '88 spring + Bilst shock up front. Then match the back to level. Equal springs on back will probably give .25" forward rake when using 2" LM rear spacer. Could shave some off spacer or go to softer spring in back to level.
kcb58h
by Jrgunn5150 » Wed Jan 21, 2015 8:44 pm
