offroadTB.com • View topic - MOD: National Luna Dual Battery Isolator
by teebes » Fri Sep 18, 2009 7:46 pm
teebes
by Philberto » Fri Sep 18, 2009 7:53 pm
I've been waiting for this... what was the cost for you?
by MrSmithsTB » Fri Sep 18, 2009 7:53 pm
Very nice! Trivial question, but to where did you relocate the rear wiper switch? Or did you simply delete it?
by teebes » Fri Sep 18, 2009 8:04 pm
teebes
by MrSmithsTB » Fri Sep 18, 2009 8:12 pm
Now if you use the wiring that is already there for some aux lighting, that would be an awesome idea. Use the existing hole for some mid-level adjustable floods. And redirect the washer hose to squirt the cars behind you on the freeway! :excited:
by Nakashige » Tue Feb 07, 2012 10:27 pm
What Gauge wire should I be using for this? is 2 or 4 enough
Nakashige
Vendor
by Trail X » Wed Feb 08, 2012 10:11 am
Depends on if you want to be able to start off your second battery or not.
Mine is 6 gauge, but I cannot start off of the second batt. If you want to start off the secondary battery, you'll need something like 0 or 00 depending on your wire length.
Bill will be able to give you more specific direction though, since he's our resident electrical engineer.
by navigator » Wed Feb 08, 2012 12:22 pm
I was trying to run an extension for a trolling motor for my canoe. That motor pulls pretty good amps and you run it continuous for long periods of time so I wanted a heavy cable to run it. I don't remember all the details but I found for that instance it was cheaper for me to buy a set of jumper cables and remove the clamps off of one end than to buy the wire separately. It might not work out that way for you and you might not be able to find them in the length you want but keep your eyes open.
by Nakashige » Thu Feb 09, 2012 1:39 am
I picked some 4 g Monster power cable today 14 feet for 20 bucks
Nakashige
Vendor
by Nakashige » Thu Feb 09, 2012 2:04 am
http://www.amazon.com/gp/product/B0026J ... %20Battery any one know if this is similar to the National Luna Kit
Nakashige
Vendor
by The Roadie » Fri Feb 10, 2012 8:55 pm
Similar idea. Cheaper, but not so cheap as to be suspiciously bad. If I was putting one in I'd go to Sierra Expeditions, though, if I had the budget.
For wire gauge, where would your second battery go, and would you want it for emergency starting? I put mine behind the driver's seat, wired to a switch off the rear fuse block feed stud. So it's fused by the Magafuse and not suitable for vehicle starting. I have a jumper box for that.
Depending on the location, I'd trust this chart:
http://www.alternatorparts.com/wire_size_chart.htm
by Nakashige » Sat Feb 11, 2012 2:02 am
Battery Box in the rear. No starting i have a jump box in the TB at all times. Powering a inverter, Aux lights, Refrigerator maybe, maybe a amp
Nakashige
Vendor
Return to Electrical / Radios
