Since the suspension lift, I haven't done anything too dramatic. Immediately after the lift, my CV axle boots gave out.
Since I didn't find swapping the axles was completely necessary, I elected to replace the boots themselves. At $10 each, why not. Coupled with 4" hose clamps, it did the job. FYI, if you take it to a shop after this, they
will bring it up and attempt to lecture you about it. Heh.
Soon after this, my front diff seal gave out, leaking all of my oil out overnight. Into my shop it goes..
This is a well documented problem and the fix is quite simple.
Everything else is cosmetic. My spare is now permanently in my trunk until I can get a CBI tire carrier. I debadged and demolded most everything on the truck save for the rear two emblems. The door handles and (soon to be) mirror covers are painted white to match the body.
..and moar stickers.
I added Z71 badges between this time and the BL on the rearmost pillar. It technically is..
I won't elaborate too much since most of what I've done has been documented by other members. I put on Mark's 3" body lift in a matter of three days, most of the time spent carefully ensuring the body doesn't roll right off of the frame. The instructions came from a mix of Mark's and Zone's. FYI, follow Mark's revised instructions to the T for 51-59. Anyway, the steering extension is easier to put in if you do it while the drivers side is still lowered. Unbolt the stock, push the slip yoke up toward the cab (assuming yours still moves) and pop 'er in there. Makes for a much easier time.
Start of it. PSA: don't do it in the grass. Stupid, stupid mistake.
Half way done. For some reason, I love this pic.
Attempted to show how much easier it is to slip in there with the driver's side down.
On my travels up north, I happened to pass by Barton's place in BFE, Indiana where he provided me venison, potatoes, and a full suite of armor for the truck. Less than a week later, it's ready to be battle tested.
All painted and ready to go (pls ignore painted grass, I tread lightly)
On the truck. I love the white rad, black bumper, and white grille. It really adds to the look.
Decided to mount two of my KCs. Was simple to do, cut some scrap metal to shape, notch, weld, grind, paint. The other two don't fit in the holes in the bumper due to the length, so I'll have to find new, slimmer ones. Also added D-rings and wheel spacers.
Also decided to indulge myself with some GM 88 springs, seeing as they're now available again. Incredible hard to do with hand compressors and socket wrenches, but nothing a little American muscle couldn't fix.
Compressed. F that, man.
