2006 Trailblazer 4.2 137,xxx miles was throwing P0300 and P0304 codes, just changed plugs with new 41-103s and now it won't run. Cylinder one an 4 showed significant corrosion.
boog2006 wrote:
I can run this with the intake resonator off right?
boog2006 wrote:I'm glad I had this little talk with myself...I'll see you tomorrow.
boog2006 wrote:After the resonator was put back on I have no issues.
Yea that guy.KingBird wrote:Manuel??? You mean Manuel Labor, the Spanish guy that works in the parts department??? Lol!
TuckerJack wrote:So, since this is the maint. blues section, figured I'd throw my two cents in... Changed the oil in the ol TB the other day after the previous owner neglected to do it for over a year and a half... I was a little reluctant to add the whole 7qts, mainly because I've never heard of any gasoline engine taking that much. Not even my V6 explorer took that much. So I only added 5.5-6 qts of 5w-30 castrol advanced full synthetic with a fram extreme guard filter for full synthetic oils. I went cheap this time because I just want to get the engine feeling a little better after not having fresh oil for over a year! However, my oil pressure gauge is jumpy now and it wasn't like that before. So while at idle, the pressure reads 40psi, but when I start to drive it jumps to 60psi. Just wondering what everyone else has experienced and if I should take out any more oil.
Naw they have random number generator when come to capacity.dvanbramer88 wrote:And what would posses you not to believe that Owners Manual for your vehicle when it came to oil capacity? You think the manufacturer is trying to trick you?
