You can wheel 35s on 89/Z71 springs and 3" of body lift. I have done it. Street driving 35s is no sweat on low lift.
SMaxx swaybar links are garbage and not really needed. If you want quick disco's search for bartonmd's thread where he shows how to build some.
If you feel you must go tall, Skyjacker C25R rear springs will net you 4" of lift with no block.
Run 10" travel Bilstein 5100 rear shocks. Search here for the part numbers.
If you are going to run a 0" backspace wheel you probably won't need spacers, however your tires will also be in your fenders whenever you turn.
If you want to go to a 6x5.5 bolt pattern run 1.5" spacers and a 25mm
offset wheel.
