A few updates... been working on the swing arm and the hinge. I was originally going to do a spindle hinge, but after looking at double shear, I decided to make my own. Started with the top hinge bracket.
Then I notched the end of the arm and welded in the tube.
Added the first bend in the arm...
Added the back support as well as the side filler/support for the top hinge bracket.
I still need to drill out a the bottom hing bracket, thats why you see the bolt sticking up as much as it is. I'm using a 3/4" grade 5 bolt for mock up. Going to see how it holds up once its in place.
I also reinforced the inside of the bumper a little where the hinge sits. This adds some support for when the arm is open.
Its slow going, but its moving. Had a bit of an issue with the latch I ordered. I found one on Amazon for $20... so I ordered it...
This is what I found in my mailbox...
So needless to say, I need to return it and order a replacement that is not meant for model cars. I still can't believe this thing was $20!
