by bartonmd » Sun Nov 24, 2013 10:09 am
Word from the tech guys at GM, third hand, is that the similar thing with the small blocks is a ring of carbon deposit at the top of the piston travel. When everything is cold, the rings tap on this ring of carbon, and make some noise. This goes away as it warms up and everything expands. They will last 300k like that. The trucks do.
Now, if you want to try and get rid of it, you could try a seafoam treatment where you suck it in a vac port until the engine dies, then let it AIT 20 min before starting again.
When the early north star v8s did this, the cure was, I shit you not, for the tech to drive the piss out of the car for 45 minutes, and burn the carbon out of the cylinders.
