offroadTB.com • View topic - 4in+ front suspension lift....alignment..????
by Tenny » Wed Aug 07, 2013 8:25 pm
hello everyone. new to the site, ive been lurking for awhile now.
here, trailvoy and GMT....I have learned a shit load for all of you
on lifting my truck.
I have accomplished 4+inches of suspension lift up front, juuuust
shy of CV binding. as a result have some SERIOUS positive camber.
I want to ask those of you that have also went with a 4in lift up...??
were you able to get the camber (close) to spec...?????
Is it TOOO much lift for the truck too handle...??? (alignment wise)???
if so, I may want to come down a bit, because I will be doing lots of road
driving, not only offroad.
thank you in advance for your time.
8-)
Tenny
by djthumper » Wed Aug 07, 2013 9:32 pm
Please tell me that you have read the stuff from this thread... viewtopic.php?f=8&t=3060
by TBYODA » Wed Aug 07, 2013 9:55 pm
I would also check out this thread. viewtopic.php?f=14&t=2290
by Conner299 » Wed Aug 07, 2013 9:56 pm
:need pics: :no pics:
Pleeeez! I, along with everyone else who peruses here, wants to see how you accomplished this.
Conner299
by DirtyBacon04 » Wed Aug 07, 2013 10:07 pm
4" lift w/o binding? I think some of our other members have done the calculations and trials w/o success. We're all very interested to see how you did it. Hopefully it wont turn you into a Zombie.............. :zombie:
by mikekey » Wed Aug 07, 2013 10:08 pm
You don't need an alignment, you'll be fine. :lurk:
by Tenny » Wed Aug 07, 2013 10:14 pm
Tenny
by DirtyBacon04 » Wed Aug 07, 2013 10:19 pm
by Tenny » Wed Aug 07, 2013 10:19 pm
Tenny
by Tenny » Wed Aug 07, 2013 10:21 pm
Tenny
by Tenny » Wed Aug 07, 2013 10:31 pm
I think you all are over thinking this whole thing...
im not talking about more than 4in....
im talking just at 4in MAX, that's all I got
I just said 4+ in the title, but I didn't mean more than 4..lol
its right at 4, and yes no binding at full droop...
Im actually just shy of it, don't plan on rock crawling
or mudding, (unless its completely nessesary) I the mud
and hate rocks, mostly trails. and where I live are lots
of dune trails, slightly wooded in some cases...
but will be also driven daily, so I wanted to know (so I don't waste my time)
if I can get this thing aligned, or is it impossible...???, than ill 86 the 88s lol.
listen im an ASE cert. master tech., I know what im talking about, and doing.
just needed to know about the alignment....before I do it.
thanks
Tenny
by Conner299 » Wed Aug 07, 2013 10:36 pm
Here is what doesn't jive, for me. Certified ASE master tech. Replaces, and modifies suspension components, up front. Why has he not done his own alignment? Or, at least tried. I'm calling BS.
Conner299
by Tenny » Wed Aug 07, 2013 10:42 pm
Tenny
by DirtyBacon04 » Wed Aug 07, 2013 10:50 pm
Wow
As i've stated... no one that I know has done a 4" suspension lift. Hence I dont know if it's possible to align the shit at that much lift. I would ask an ASE Master Tech if i knew one...
Do you already have a 4" lift or are you talking hypotheticals? Have you flipped your control arms? Replaced CV's with cardone boots? We're trying to help you, but you gotta swallow your pride for a sec and give us a better reply with better grammer.
But short answer; no, you wont get the alignment perfect. at 3" camber can be corrected, and caster usually wont, not that caster matters.
by Conner299 » Wed Aug 07, 2013 10:54 pm
90% of anyone asking if they need an alignment, after a lift, has already had this question answered. To MANY differing degrees. People have even posted photos, of their alignment sheets, pre and post alignment. If you've been reading, as much as you say, your question would've already been answered.
EDIT: Meant to say: "If their vehicle can be aligned."
Conner299
by Trail X » Wed Aug 07, 2013 10:57 pm
Flip the control arms, that's about the best you can do. It sounds strange, but it brings the ball joint out, into the adjustment range of the LCA. Some of us get it in spec, and some of us are a bit outside the limits, but close. My caster is in, but I'm still out on camber.
Sorry about the hecklers... they seem to like to bash the new guy lately without actually being helpful.
by drburke » Wed Aug 07, 2013 11:00 pm
It sounds like you flipped your UCAs. That's exactly what mine did. Three of the shops I went to wouldn't touch it unless I flipped them back. This was before I put spacers on though, so YMMV.
FYI, I have 88s and mark's 3" lift w/o uca flipped and I don't have any alignment issues. If you've read the threads pertaining to lifts, you'll see the most we have is a 3" spacer + whatever spring rate you install for the front. We have quite a lot of members running 3" + 89s w/o binding or alignment issues.
drburke
by mikekey » Wed Aug 07, 2013 11:05 pm
by Moots1288 » Wed Aug 07, 2013 11:07 pm
by mikekey » Wed Aug 07, 2013 11:08 pm
