hilift jacks
by c bausch » Wed Jan 25, 2012 4:08 pm
Hey guys I wanted to get first hand experiences on hilift jacks I was thinking about getting one for the tb. Im past the stock jack height that comes with the truck and suggestions on the height of the jack? I got a 3 inch suspension lift with 33's but that's about it and are they reliable for the money?
c bausch
by Gordinho80 » Wed Jan 25, 2012 4:16 pm
You can probably find one on Craigslist... I got mine with a little use for very cheap. Unless you have sliders, you'll need the "Lift Mate" attachment to jack up the truck by the wheels.
by djthumper » Wed Jan 25, 2012 4:16 pm
by navigator » Wed Jan 25, 2012 4:19 pm
I think if you did a lot of searching they are more of a recovery tool than a true jack to like change a flat.
Unless you have rock sliders and a steel bumper to hook to you won't be able to jack up to change a tire.
If you are just too tall to use your scissors jack, carry a block of wood to put under the jack with you to make up the difference in height.
If you get the adapters and need to use it as a winch, or get the lift mates and need to lift a tire out of a rut and back fill the hole, I understand they work well as an all around recovery tool.
by chevycrew » Wed Jan 25, 2012 4:36 pm
I always carry mine with me, but I have sliders to jack off of. Carrying an axle strap will aslo help, it attaches the axle to the frame to prevent suspension droop so you dont have to jack the rig up as high.
by NC_IslandRunner » Wed Jan 25, 2012 4:58 pm
navigator wrote:I think if you did a lot of searching they are more of a recovery tool than a true jack to like change a flat.
Scissor jack? I didn't know any TB's came with a Scissor jack. Mine is a crank bottle jack but I keep a hydraulic bottle jack in the truck.
by c bausch » Wed Jan 25, 2012 5:42 pm
I search about them but wanted to know what everyone here thought about them
c bausch
by navigator » Wed Jan 25, 2012 5:46 pm
NC_IslandRunner wrote:...
You're right man, I've seen mine before but I don't think I've ever had to use it. I use the floor jacks here at the house.
I've only used the jack handle to lower and lubricate the spare tire lift assembly.
by Trail X » Wed Jan 25, 2012 6:02 pm
Just to add two more cents...
If you don't have sliders, the jack isn't completely useless, but your real utility comes from using them with sliders.
Otherwise you can use it as a winch, but it can't really replace a bottle jack.
by fishsticks » Wed Jan 25, 2012 6:13 pm
If you have the factory tow hooks, it's possible to wrap a tree saver strap around them and use the HiLift through the strap eyes. You'll want someone watching the jack the whole time you're working though.
You can also lift the rear of the truck by the trailer hitch with a HiLift.
by DirtyBacon04 » Wed Jan 25, 2012 6:38 pm
I aint got no sliders, and I've probably used my highlift 100 times. Great tool.
by djthumper » Wed Jan 25, 2012 7:14 pm
100 times in one late night?
by DirtyBacon04 » Wed Jan 25, 2012 7:15 pm
Pinyon Squeeze tested!!
by TSAdventurez » Wed Jan 25, 2012 7:26 pm
Saved my ass plenty of times used it as a winch several times well worth the money in my book!
TSAdventurez
by c bausch » Wed Jan 25, 2012 7:34 pm
Swsome do you guy usually get the 48" jack or the 60"?
c bausch
by DirtyBacon04 » Wed Jan 25, 2012 7:35 pm
i have the 90" highlift
by TSAdventurez » Thu Jan 26, 2012 12:34 am
I have the 48 inch one so I can lay it down behind the second row of seats and it fits perfectly across the roof rails.
TSAdventurez
by chevycrew » Thu Jan 26, 2012 2:32 am
Also for those wanting to keep a hilift clean and tucked away. Mine is laying inside the passenger doors on the jam between the seats and the doors. The base is just in front of the rear seat, and the handle and "I" beam comes up into the front passenger floor area. Always easy to access, stays clean, and doesnt hurt the entry too bad.
by Nakashige » Thu Jan 26, 2012 3:10 am
48 hilift extreme love it for winching and repairs
Nakashige
Vendor
by c bausch » Thu Jan 26, 2012 11:03 am
There's a hilift 48"jack on craigslist for $50 guy said its in perfect condition alls I know is that its black think its a good buy?
c bausch
