WTB 4WD Disconnect
by Ole Blue » Thu Feb 13, 2014 7:22 pm
Wanting to buy a disconnect for a 02. The original part number is ATP 11101 but I will also take a ATP 11102.
Being badass ain't cheap, being cheap ain't badass
Ole Blue
by The Roadie » Thu Feb 13, 2014 8:40 pm
Amazon and Ebay vendors out of stock?
by Ole Blue » Fri Feb 14, 2014 4:06 pm
I found one on amazon for about $360
Ole Blue
by DustinC1989 » Fri Feb 14, 2014 8:09 pm
That's a pretty good price
DustinC1989
by Ole Blue » Fri Feb 14, 2014 8:52 pm
Yeah I'm might end up getting it, I just wanted to see what could I find on here. Is the ATP 11102 upgrade worth it?
Ole Blue
by DustinC1989 » Fri Feb 14, 2014 9:03 pm
Do you need an entire disconnect?
Could just rebuild yours with a AWD sleeve for about half the price
DustinC1989
by Ole Blue » Fri Feb 14, 2014 9:08 pm
Well I work 6days a week. I was planning on replace the old one with a new one and rebuilding the old one as a spare.
Ole Blue
by DustinC1989 » Fri Feb 14, 2014 9:20 pm
Makes sense, I rebuilt mine when I was working 6/12's and it certainly was not fun.
IIRC, the only problem with the AWD disconnect is not having a location for the 4wd shift motor, it can just be zip tied out of the way. But it has to be left plugged in to prevent issues
DustinC1989
by Ole Blue » Fri Feb 14, 2014 9:37 pm
So upgrading to the ATP 11102, when installed and driving around town do I leave it in 2hi or A4WD? And for the hanging motor I was gonna wrap it somehow and zip tie it to the frame somehow.
Ole Blue
by DustinC1989 » Fri Feb 14, 2014 10:00 pm
2hi
I NEVER use auto and recommend the same
DustinC1989
by Ole Blue » Fri Feb 14, 2014 10:19 pm
So I should just stay in 2hi and not go to A4WD with the 11102 installed?
Ole Blue
by v7guy » Fri Feb 14, 2014 11:25 pm
The consensus on here is about the only scenario you want to attempt to use the A4WD is if you're on a icy side road pulling into a clear road, you'll want to move to 2hi right after you get in the clear road though.
When A4WD engages it's slamming a geared sleeve over two other gears rotating in opposite directions, as you can imagine, that's hard on the parts.
by Ole Blue » Sat Feb 15, 2014 12:13 am
Gotcha, I know about that. I only asked cause the 11102 is mainly for AWD while the TB is mainly in 2hi and didn't want to cause any usual wear on the new disconnect.
Ole Blue
by Wahugg » Sat Feb 15, 2014 2:58 am
v7guy wrote:The consensus on here is about the only scenario you want to attempt to use the A4WD is if you're on a icy side road pulling into a clear road, you'll want to move to 2hi right after you get in the clear road though.
Actually in auto4, the disconnect is already engaged and the clutch in the transfer case is what engages. Yes it is still hard on parts such as the disconnect, but the disconnect is only disconnected in 2hi and is never used as an on/off in auto4 mode.
-Wahugg
Wahugg
by Ole Blue » Sat Feb 15, 2014 3:05 am
Gotcha. I think I'll just order 11101 and rebuild the old one which was the original plan. Thanks for the input everyone.
Ole Blue
