CONFIRMED: Fabtech 2500HD Tie Rod Ends - DO NOT USE
by Diacom » Mon Feb 03, 2014 11:35 pm
Ahh, my miss understanding then, I thought you meant that their own online pricing was about that much more than the in store price, which can happen.
The only issue I have with Rock Auto, is often the savings in parts is chewed up quickly by the shipping and on some multi application listings for other models, I've had the wrong part sent, even when I order the correct one. Returning parts to them isn't saving any money that way either.
But I do still buy from them when I'm not in an immediate need of a part or parts.
by mikekey » Mon Feb 03, 2014 11:41 pm
I actually haven't found that much savings with Rock Auto, and you're right about their shipping. But this time on the TRE's they actually came out as cheaper, even with their slow shipping.
by Aries » Tue Feb 04, 2014 9:15 am
mikekey wrote:Well, everyone can proceed to laugh at me for my expensive lesson
Well your not alone Image I all ready have them in the my shop, I was waiting until I change my tires over to install them. Let me know how it goes.
Aries
by HARDTRAILZ » Tue Feb 04, 2014 9:44 am
He already told you how it goes....IT DON'T.
by Moots1288 » Tue Feb 04, 2014 9:46 am
Read man.
by Trail X » Tue Feb 04, 2014 10:13 am
HARDTRAILZ wrote:That's about as rare as upper control arm failures. :raspberry:
Kinda... 50% less rare... but you can still drive a long way with an inner TRE bent. Not so much with a broken UCA.
by DirtyBacon04 » Tue Feb 04, 2014 8:18 pm
Oh, Kyle... It goes..................... in a straight line
Probably got the turning radius of a funny car
by mikekey » Tue Feb 04, 2014 8:31 pm
Actually from measurements it's probably around 40ft. It's not the stock 18.2ft turning radius that makes these things great.
by Aries » Tue Feb 04, 2014 8:56 pm
HARDTRAILZ wrote:He already told you how it goes....IT DON'T.
Moots1288 wrote: Read man.
No shit really. Image
Aries
by The Roadie » Tue Feb 04, 2014 10:00 pm
My bent inners (happened twice) occurred during incidents where the outers bent first at the end of the threads where the bend starts on the non-threaded part. When overstressed, the side force from the bent part gets the weak part at the threaded end to break. But as it's deforming, the firce bends the inner tie rod shaft where you've seen. Here's the outer during one of those incidents.
by mikekey » Thu Feb 06, 2014 4:24 pm
While this doesn't change the fact, I got my hands on an HD tie rod end to show you the difference.
BOOM :awesome:
The Fabtechs are surprisingly really big in comparison. Even when compared to the OEM ones.
by ErikSS » Fri Feb 07, 2014 10:42 am
Thanks for the comparison Mike. I didn't realize how different the diameter was until you posted the pic of it against your rack. Have you decided to try Moogs? Rough Country sleeves?
by mikekey » Fri Feb 07, 2014 10:44 am
ErikSS wrote:Thanks for the comparison Mike. I didn't realize how different the diameter was until you posted the pic of it against your rack. Have you decided to try Moogs? Rough Country sleeves?
I have no plans to.
by ErikSS » Fri Feb 07, 2014 2:25 pm
What do you plan to run? Trying something else Top Secret?
by mikekey » Fri Feb 07, 2014 2:41 pm
I don't need tie rods, they're over rated.
by jonbo2002 » Fri Feb 07, 2014 2:49 pm
just get out and point your wheels where you need them to go with your hands
jonbo2002
by ErikSS » Fri Feb 07, 2014 2:55 pm
jonbo2002 wrote:just get out and point your wheels where you need them to go with your hands
Hahahaha lololol hahaha
Thanks man. I needed a good laugh!
by jonbo2002 » Fri Feb 07, 2014 3:00 pm
:fro: :thumleft:
jonbo2002
by v7guy » Sun Feb 09, 2014 12:31 pm
Mike, I don't suppose you happened to take down the inside measurement of the rack with a pair of calipers did you?
by mikekey » Sun Feb 09, 2014 12:57 pm
Nope. If I had been more observant before I removed the tie rods I could of never unboxed these.
