Hello from West Virginia
by Regulator1175 » Thu Jan 30, 2014 10:31 pm
Welcome to the site. I was born in Charleston, and all my family on my mother's side is from that central WV area. I have wheeled a couple times out there and loved it.
Sent from my SCH-I545 using Tapatalk
by Hillbillybonez » Thu Jan 30, 2014 10:35 pm
HARDTRAILZ wrote:31-10.50's....are they 15s? Did you use adaptors?
Sounds like your truck did what mind did to me...surprised the heck out ya nd got the wheels turning to make it into something more fun and capable. You got the right ideas I think, so WELCOME.
Yeah 15's and Spacers were added
Hillbillybonez
by Hillbillybonez » Thu Jan 30, 2014 10:39 pm
The Roadie wrote:Welcome! I'm compelled to mention to all new members if they're new to the platform, that the transfer case fluid change interval is a surprisingly short 50K miles, and it ONLY takes GM Auto Trak II fluid. 2 liters. How many miles does it have, and are you current on the TC fluid and the other 100K maintenance?
This was my worrie as well, So this weekend It will be changed. it has 170k miles on it. who ever had it ( before my wifes friends ) took very good care of it. Course today on the way home from work I found it will not not engage in 4wL turn the switch to low and the light blinks and it switches back to 4 high.. so I think its time to pull it into the garage and give it a full look over.
Hillbillybonez
by TBYODA » Thu Jan 30, 2014 11:21 pm
Hillbillybonez wrote:Course today on the way home from work I found it will not not engage in 4wL turn the switch to low and the light blinks and it switches back to 4 high.
Did you have TB stopped and in natural?
by Hillbillybonez » Fri Jan 31, 2014 12:09 am
Yeah, I came to a complete stop and nothing, just the light flashed and then it returned back into 4w high
Hillbillybonez
by HARDTRAILZ » Fri Jan 31, 2014 9:47 am
You dont want a complete stop, but rolling at a mile or two per hour(in neutral) seems to allow everyting to sync up better. Try that once if you get the chance.
by Hillbillybonez » Fri Jan 31, 2014 10:37 am
ok Ill give that a try this evening, thanks
Hillbillybonez
by Trail X » Fri Jan 31, 2014 11:11 pm
Hillbillybonez wrote:Yeah, I came to a complete stop and nothing, just the light flashed and then it returned back into 4w high
Don't forget the neutral part. It won't shift to low range if you're in drive.
by HARDTRAILZ » Fri Jan 31, 2014 11:20 pm
Naturally it (seems someone else mentioned that)
by Trail X » Sat Feb 01, 2014 12:05 am
Thanks ball buster.
by HARDTRAILZ » Sat Feb 01, 2014 12:16 am
No problem chief. Glad to help out ;)
