offroadTB.com • View topic - Fixing my steering today...
by Moots1288 » Wed Sep 25, 2013 8:42 pm
by fishsticks » Fri Sep 27, 2013 1:49 am
So....who's going to be the first to shatter a steering rack? :mrgreen:
by v7guy » Fri Sep 27, 2013 2:50 am
by Moots1288 » Fri Sep 27, 2013 10:47 am
by mikekey » Fri Sep 27, 2013 1:07 pm
I'm thinking of pulling the trigger on those Poly's or the Fab Tech here soon.
by Moots1288 » Fri Sep 27, 2013 1:10 pm
by ErikSS » Fri Sep 27, 2013 1:27 pm
I like the rare parts TREs. But I'm going Moog based on need and value. $167 a set on Ebay and then use jam nuts on the threads....
by mikekey » Fri Sep 27, 2013 2:03 pm
I meant the Rare Parts, but got them backwards when I was typing it up.
There are some completely unnecessary mods I want to do, so I'm just buying things up. Like, I want to powder coat my next set of CV's. I like the idea of overly heavy duty TRE's I won't have to worry about. That should last us just like the OEM's did in stock mode.
by Moots1288 » Fri Sep 27, 2013 2:12 pm
by mikekey » Fri Sep 27, 2013 3:41 pm
Yeah I just need to check measurements.
by blazinlow89 » Mon Dec 09, 2013 12:54 am
blazinlow89
by mikekey » Mon Dec 09, 2013 8:33 am
Indeed I did and I bought the Fabtechs.
by blazinlow89 » Mon Dec 09, 2013 8:45 am
Good to know, might be one of my next mods. I also assume they have more adjustment range than the OEM ones?
blazinlow89
by mikekey » Mon Dec 09, 2013 9:44 am
Yes, a matter of fact, I'll post a picture later today.
Originally I saved all 3 of the TRE's in ebay and then forgot to recheck this thread about the Fabtechs. I had Fabtech on the brain from AlekG's post about the dirt logic shocks. Anyhow, I ended up ordering them.
But going back and looking at these compared to the Rareparts, I'd be slightly concerned that the Rareparts TRE's don't adjust enough for our vehicle since they are for the Silverado. I'm not sure if the distance from the inner on the rack and pinion to the outter is longer on the Silverado, but it is an assumption.
For me the outters slid right in place. No need to use a taper like Fishsticks had to in the beginning of this thread. I have a stock inner/outter and the threads on the Fabtech inner match. So hopefully when I get back to round two of trying this I can get the whole damn things on and report.
Based on your build thread on GMT you might just want to save yourself the money and get the regular 2500HD tie rod ends.
by blazinlow89 » Mon Dec 09, 2013 10:17 am
Some things have changed since I started that build thread. Might just spring for the Fabtechs, I want to be once and done. Pricing everything out it may only cost an extra $100 as I have found the Fabtechs for around $250.
blazinlow89
by Moots1288 » Mon Dec 09, 2013 10:19 am
by ErikSS » Sat Dec 28, 2013 11:03 pm
by HARDTRAILZ » Sat Dec 28, 2013 11:18 pm
Moots n Janesys also had to replace theirs earlier.
by ErikSS » Sun Dec 29, 2013 1:50 am
by HARDTRAILZ » Sun Dec 29, 2013 3:11 pm
Mine leaks, but I just keep throwing fluid in it since it is not the DD anymore.
